[SOLVED] Can wapt-get.ini be modified by group?
louisinger
Registration: June 26, 2018 - 09:40
July 5, 2018 - 9:50 AM
I would like to know if the Wapt agent can be modified by machine group or even across the entire network. Are we really required to configure each workstation individually?
July 5, 2018 - 10:35
I think the question is ambiguous.
Do you want to modify the local WAPT agent configuration automatically?
In that case, create a package that modifies the parameters in wapt-get.ini and assign it to a group or a multi-select list of machines.
Or do you want to configure the machines in bulk?
In that case, create a group, assign packages (group or software) to it, and assign the group to a multi-select list of machines (this only needs to be done once). You can then manage this group of machines by adding or removing packages from the group.
louisinger
July 5, 2018 - 10:50
Do you want to modify the local Wapt agent configuration automatically?
If so, create a package that modifies the parameters of wapt-get.ini and assign it to a group or a multi-selection of machines.
That's right, I wanted to know if I needed to script the modification of the .ini file. Thank you.
I have another question: is there a command to update/upgrade a selection of machines?
July 5, 2018 - 11:13
For scripting wapt-get.ini:
example: https://store.wapt.fr/package_details?p ... 4_all.wapt
To update/upgrade selected machines
, simply make a multi-selection in the console and press the "Apply Upgrades" button.
All machines will receive the order to update.
louisinger
July 5, 2018 - 11:37
Thank you so much!
