FATAL ERROR: TypeError: not enough arguments for format
olivetree
Registration: February 19, 2018 - 10:42
June 14, 2018 - 5:29 PM
Wapt 1.5
Windows Server 2012 R2
I wanted to create a package to install and configure Dell Command & Configure.
Through the console's graphical interface, I was getting string or argument errors.
I tried using the command line:
c:\waptdev>wapt-get make-template C:\Users\wstaff\Downloads\Dell-Command-Configure.EXE tarkin-Dell_Command_Configure
And in return I get this error:
FATAL ERROR: TypeError: not enough arguments for format string
If I use the assistant, I do it like this (image below) and it gives this result (next image)
Do you have any idea?
/r/ComedyCemetery/ "If I install Windows 10 of 32 bits twice... Will it become 64 bits?"
System Management Blog https://deployadmin.com/
julienlevi
Registration: May 4, 2018 - 09:18
July 5, 2018 - 4:32 PM
I'm experiencing the same issue with an .msi file.
Does anyone have a solution?
Thanks.
July 5, 2018 - 5:34 PM
Hello Olivier,
olivetree wrote: ↑June 14, 2018 - 5:29 PM Wapt 1.5
Windows Server 2012r2
I wanted to create a package to install Dell Command & Configure.
Using the console's graphical interface, I was getting string or argument errors.
And I get this error:
If I use the wizard, I do it like this (image below) and it gives this (next image)
The problem stems from a special character (a pipe |) in the "product name" field of the file attributes, and a bug in the package creation wizard. I'll check with Hubert to fix this bug. I've created two issues related to this problem.
https://roundup.tranquil.it/wapt/issue959
https://roundup.tranquil.it/wapt/issue960
However, it works for me via command line (version 1.6.1) with the file downloaded from the website https://www.dell.com/support/home/fr/fr ... erid=fvgf9 Something to look into.
Note: you can always create your package by creating an empty package and putting the executable inside.
julienlevi
July 6, 2018 - 12:09
Since I only have the MSI file available, I can't create a package with an EXE file :(
July 6, 2018 - 6:42 PM
In the meantime, you can execute the following command:
 wapt-get make-template tarkin-dell-configure
(Be sure to delete the tarkin-dell-configure folder in c:\waptdev before running the command)
You can then copy the binary (exe or msi) directly into the folder c:\waptdev\tarkin-dell-configure\
And write your package
julienlevi
July 11, 2018 - 4:43 PM
Thank you so much, it worked!
