when I open the wapt console (version 1.5.24) and navigate to the private repository, it's empty and displays the following error message:
An unhandled exception has occurred
. Exceptions.ValueError: invalid literal for int() with base 10: '1399a27'
Debian server,
Windows 7 client.
Can you help me, please?
Regards
[RESOLVED] Empty private repository and error message
is this a "fresh" installation or an update of WAPT from a previous version?
Alexandre
Alexandre
I suspect one of your packages has a non-canonical version... the console isn't tolerant.
Package versions must follow the format "1.2.3.4-5".
Check your repository directory on the WAPT server (c:\wapt\waptserver\repository\wapt on Windows) to see if a file is named with a version number of 1399a27.
If so, set that package aside and rescan for packages manually (wapt-scanpackages c:\wapt\waptserver\repository\wapt or wapt-get update-packages c:\wapt\waptserver\repository\wapt on Windows).
Thank you for this information, but the server is running Debian, could you please provide me with the commands?htouvet wrote: ↑Jul 12, 2018 - 9:32 AM I think one of your packages has a non-canonical version... the console isn't tolerant.
Check in your repository directory on the WAPT server (c:\wapt\waptserver\repository\wapt on Windows) if a file is named with a version number of 1399a27.
If so, set that package aside and restart the package scan manually (wapt-scanpackages c:\wapt\waptserver\repository\wapt or wapt-get update-packages c:\wapt\waptserver\repository\wapt on Windows).
on the server:
ls /var/www/wapt/*1399a27*
mv /var/www/wapt/*1399a27* /root/
wapt-scanpackages /var/www/wapt
Problem solved!
I found the package in question, removed it, and ran the following commands:
/opt/wapt/wapt-scanpackages.py /var/www/wapt/
/opt/wapt/wapt-scanpackages.py /var/www/wapt-host/
/opt/wapt/wapt-scanpackages.py /var/www/wapt-group/
Thanks again for your help!
