sorry if the answer seems obvious, but I'm a beginner in Python.
Currently, I create several packages on the WAPT server and then deploy them.
If I need to make changes, I modify the package's setup.py file on the server, then rebuild the package and redeploy it.
The problem is that during testing, I end up rebuilding the package countless times just to test a function or syntax.
Isn't there a way to execute functions from the client machine directly in setuphelpers to perform these tests?
When I try to import setuphelpers on the client machine, I get the error message: "
No module named setuphelpers".
If anyone has a solution, I'd be very grateful!
Thanks in advance.
[SOLVED] Test script locally
See PyScripter and the test configurations:
https://www.wapt.fr/fr/doc/CreationPaqu ... index.html
Wapt has its own Python installation (=virtualenv).
Your local test environment must therefore be configured to use Wapt's virtualenv.
With PyScripter, it is very easy to test your package and the setuphelpers functions (integrated Python shell: "from setuphelpers import *").
Hello htouvet,
thank you very much for your reply.
However, I'm having trouble launching PyScripter.
After installing it on the client machine via WAPT, I can't open it. When I try to launch it, I get the error message: "
Could not load a Python engine."
I saw that a 32-bit version of Python needs to be installed for it to work with PyScripter.
https://github.com/pyscripter/pyscripte ... nstall.txt
I also saw a workaround by adding a batch file to the PyScripter executable folder:
https://groups.google.com/forum/#!topic ... BbYQSCO0uQ
The batch file contains:
SET PYTHONHOME=C:\Python27
PyScripter --PYTHON27 --PYTHONDLLPATH "C:\Python27"
Despite this, I still can't open PyScripter.
According to the error message "Could not open DLL file: Error 193", this appears to be an architecture issue incompatible with the DLL.
The machine is running Windows 7 64-bit.
Do I need to download a specific Python27.dll file? And if so, where can I find it?
David
David
- WAPT Expert
You need to launch PyScripter through Wapt.
Right-click on a package and select Edit.
Alternatively, use the "Package Builder Wizard" from the console.
Or, open an existing PsProj file with C:\Program Files (x86)\wapt\waptpyscripter.bat.
In PyScripter, go to Project > Open Project > Open PsProj.
thank you for this information.
I can now open the psproj file of the package in question from PyScripter.
However, when I run the code in the setup.py file, it returns the error: "
In the psproj directory structure in PyScripter, I do see a setuphelpers file, but:
1. I don't know how to point to it
. 2. The setuphelpers file is empty!
Sorry, I imagine my question is very basic and simple, but I'm not sure how to proceed...
Thanks again for your help.
David
David
Rest assured, what you're asking isn't trivial...
There are potentially two problems:
- Python environment
- Paths in the wapt.psproj file.
Python Environment:
Wapt actually has its own Python interpreter and environment (in c:\program files(x86)\wapt).
And PyScripter doesn't initially know about this environment.
If you have version 3.4.1 of PyScripter (the one in our repository), there's a function that allows you to add the path to Wapt's Python environment to PyScripter, so that all the associated libraries (including setuphelpers) are available.
the Run menu / Python Versions / Setup Python
. Click the + button and select the Wapt directory (by default, c:\program files(x86)\wapt).
In the "Unregistered Versions" list, select the Wapt folder and click the first button in the top left corner (Activate selected python version).
From there, you can test and debug without errors.
There's a button (Python icon) in the PyScript toolbar to do the same thing.
Another solution is to use the Waptconsole to edit the package. When the console launches PyScript, it sets the correct environment variables and arguments so that PyScript uses the Wapt interpreter.
Alternatively, you can use the command line:
`wapt-get edit`
This does the same thing as in the console.
Paths in the wapt.psproj file:
The wapt.psproj file stores the paths (absolute in earlier versions of Wapt...) to, among other things, the wapt-get.py file.
wapt-get.py is used to test packages.
You must verify this by right-clicking on the run configuration (Run configuration), for example, "install" / Edit run configuration.
The Python script / File name: must point to the correct directory for your installation. Normally c:\Program Files (x86)\wapt, but previously it was c:\wapt).
Python Environment:
`wapt-get edit`
Hello htouvet,
a huge THANK YOU!
After adding the Wapt folder path to "Unregistered Versions" and enabling it, everything works!
I can finally run all my tests locally on my test machine.
The server solution is also interesting, but in this case, it's mainly for testing things on a specific machine.
And, indeed, the paths in the wapt.psproj file point to the old Wapt installation folder.
So I was able to change them.
Again, thank you so much for your help and all these detailed explanations!!!
Have a good day,
David
a huge THANK YOU!
Have a good day,
David
