just FYI, I updated to version 1.5.1.23 without any problems except for Syncthing, which stopped working after the update. I had to run `chown -R wapt:www-data /opt/wapt/.config/` and restart the service for it to work.
Thanks to TranquilIT.
Upgrade 1.5.1.23
- WAPT Expert
Yes, indeed, it's true that the installation overwrites the permissions on that directory
I had the same problem when upgrading to version 1.5.1.26
Thanks btravers for the solution!
