infected waptserver package
TheBarz
Registration: August 1, 2018 - 3:51 PM
August 1, 2018 - 3:57 PM
I'm writing to inform you that the package is (apparently) infected with a virus. I just downloaded it, and Symantec is detecting it as a virus.
I downloaded version 1.5.23 a few weeks ago, and it worked fine. (Except that it no longer works now.:( )
agauvrit
Registration: Nov 17, 2016 - 10:25
August 1, 2018 - 4:29 PM
which package are you referring to?
From which URL did you download it?
It's possible this is a false positive caused by nssm.exe – this is discussed in the documentation: https://www.wapt.fr/fr/doc/Frequent-pro ... -antivirus.
I'm waiting for your information to understand why your antivirus is malfunctioning.
TheBarz
August 1, 2018 - 4:46 PM
Coming from this link: https://wapt.tranquil.it/wapt/releases/ ... rsetup.exe
Note that the working package does not have this problem.
Note that the error reported by Symantec is: Infected by PU1.Gen.2
I wondered about nssm. But the installation binaries are on a volume excluded by the antivirus, which surprises me...
https://www.symantec.com/security-center ... 4294907775
agauvrit wrote: ↑August 1, 2018 - 4:29 PM Hello,
Which package are you referring to?
From which URL did you download the package?
It's possible this is a false positive caused by nssm.exe - this topic is covered in the documentation: https://www.wapt.fr/fr/doc/Frequent-pro ... -antivirus
agauvrit
August 1, 2018 - 5:20 PM
It's strange that Symantec is only taking action for a generic signature like this.
The VT analysis results are here: https://www.virustotal.com/fr/file/4987 ... /analysis/
We're looking into why.
Thanks for your feedback.
TheBarz
August 1, 2018 - 5:25 PM
If this is confirmed, I can raise this issue with Symantec.
