[SOLVED] mass forget package
Empbilly
Registration: January 15, 2018 - 8:59 PM
August 8, 2018 - 2:13 PM
I know that I can do this manually, but is there any way to select and have mass forgotten packets that are no longer part of the host?
Empbilly
August 27, 2018 - 1:15 PM
Anyone have an idea if my question posted above is possible?
August 27, 2018 - 2:30 PM
Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
Empbilly
August 28, 2018 - 4:59 PM
htouvet wrote: August 27, 2018 - 2:30 p.m. Make a multi-selection of the target hosts (Ctrl+Click / UpperCase+Click) and make the focused one has the package you want to forget, then right click on the package / Forget.
Thanks htouvet!!! Works!!! :)
