Are src.rpm files available?
Come here to talk about your experience with Samba4, your opinion and your wishes.
ElCoyote
Registration: May 2, 2018 - 8:58 p.m.
May 2, 2018 - 9:00 PM
I'm using your RPMs but I'd like to start rebuilding them to add a patch. Are your source RPMs (src.rpm) available somewhere?
Thanks,
Vincent
May 3, 2018 - 09:23
Hello Vincent,
ElCoyote wrote: ↑May 2, 2018 - 9:00 PM I'm using your RPMs but I'd like to start rebuilding them to add a patch. Are your source RPMs (src.rpm) available somewhere?
We reuse Fedora packages that we backport to CentOS. And the compilation is a bit more complicated than just running `rpmbuild` on the Samba `src.rpm` because of dependencies like libldb, libtalloc, libtevent, Python 2 vs. Python 3, etc. The complete recipe is in our Jenkins repository.
Is the patch you want to install the one to fix the upgrade issue from 4.7 to 4.8.1? I think we'll integrate it this week.
ElCoyote
July 9, 2018 - 4:21 AM
Is it possible to access your .spec files and your Jenkins recipes for Samba (read-only, of course)?
Let me explain: I thought you regularly updated your Samba RPMs. Versions 4.8.3 and 4.7.8 have been out for a while now, and I'm wondering about the operational risk of continuing to use your RPMs: unsigned binary RPMs, undistributed/unpublic src.rpm files.
In other words, it would be impossible to rebuild the RPMs by updating them if you (tranquil.it) all went on vacation at the same time. :)
Would it be possible, at the very least, to distribute the differences between your .specs and those of EPEL? Any starting point would be appreciated.
Thank you in advance,
Vincent (who works for an open-source publisher that distributes all the src.rpms but uses -your- RPMs personally).
nqb
Registration: July 18, 2018 - 6:30 PM
July 18, 2018 - 6:34 PM
I agree with ElCoyote.
Do you have a release date for the RPMs for version 4.7.8?
mauro
Registration: Sep 08, 2018 - 5:01 p.m.
September 8, 2018 - 5:03 PM
There is a new repository with samba 4 with Domain Controller for CentOS and RHEL 7 that also provides the source packages:
Please see:
http://www.ezplanet.net/xwiki/bin/view/EzPlanetRepo/
September 17, 2018 - 11:03
Hello ElCoyote,
ElCoyote wrote: ↑July 9, 2018 - 4:21 AM Hello,
That is: it would be impossible to rebuild the RPMs by updating them if you (tranquil.it) all went on vacation at the same time. :)
Thanks in advance,
Vincent (who works for an open-source publisher that distributes all the src.rpm files but uses -your- rpms personally)
Jérémie placed the SRPM files in the following directory:
https://samba.tranquil.it/centos7/SRPMS/
We will see later how to create a nice standard CentOS/RedHat directory structure.
September 17, 2018 - 11:20
Hello nqb,
nqb wrote: ↑July 18, 2018 - 6:34 PM Hello,
Do you have a delivery date for the RPMs for 4.7.8?
RPM versions 4.7.10 and 4.8.4 were published by Jérémie: Sincerely,
nqb
September 17, 2018 - 1:33 PM
Thank you Denis
ElCoyote
September 17, 2018 - 3:07 PM
Thank you, that's very much appreciated.
Do you think you can continue to upload .src.rpm files systematically when you release new versions?
That would be absolutely fantastic. Thanks again
Vincent
dcardon wrote: ↑Sep 17, 2018 - 11:03 AM Hello ElCoyote,
Jérémie placed the SRPMs in the following directory:
We'll see later about creating a nice standard CentOS/Red Hat directory structure.
Regards,
vcardon
September 17, 2018 - 8:17 PM
ElCoyote wrote: ↑Sep 17, 2018 - 3:07 PM Thank you, that's very much appreciated.
Do you think you could continue to upload the .src and .rpm files systematically when you release new versions?
That would be fantastic. Thanks again,
Best regards,
Vincent
Tranquil IT cannot commit to such a promise because it is work and all work must be compensated.
We will do it as long as we find an advantage or a way to make the most of that time.
Sincerely.
Vincent (... also)
