[SOLVED] Firefox ESR package update issue
PPE
Registration: March 19, 2018 - 5:03 PM
September 21, 2018 - 12:01
I'm having trouble deploying the Firefox ESR update from 52.x to 60.x.
I would like this update to happen automatically. I've moved the firefox-esr 60.x package to my private repository; it has the same name as the old 52.x package.
Unfortunately, the update isn't happening on the machines. They remain on 52.x.
How can I set up this deployment?
Thank you in advance.
September 21, 2018 - 6:57 PM
Hello PPE,
PPE wrote: ↑Sep 21, 2018 - 12:01 PM I'm having trouble deploying the Firefox ESR 52.x to 60.x update.
This is sorely lacking in information to be of any use... As mentioned in Alexandre's pinned topic at the top of the forum [1], could you please specify the version and server OS?.
Next, could you provide the output of the following command when run as Administrator (with elevated privileges) in a cmd.exe window?
wapt-get update
wapt-get upgrade
wapt-get search firefox
[1] viewtopic.php?f=9&t=886
PPE
September 24, 2018 - 08:29
Yes, I wasn't clear enough in my question.
WAPT version installed: 1.5.1.23
Server OS: Windows Server 2012r2
Administration/package creation machine OS: Windows Server 2012r2
The command output is attached.
Screenshot 2018-09-24 at 08:28:59.png
Screenshot 2018-09-24 at 08:28:59.png (43.45 KB) Viewed 10387 times
September 24, 2018 - 09:11
We also needed the control file from your wapt firefox esr 60 package
PPE
September 24, 2018 - 10:47
So.
control.zip
(1.29 KB) Downloaded 422 times
September 24, 2018 - 5:23 PM
Your package is in
architecture      : x86
Can we have the package? x64 From your deposit?
PPE
September 24, 2018 - 5:38 PM
Indeed, with the correct package, the update goes much more smoothly....
Thank you for pointing me in the right direction.
Have a good evening.
