I have a question about replication using the tissyvol script, which used to work fine but seems increasingly slow.
With htop, I get dozens of `/opt/tis-sysvolsync/bin/syncthing -no-browser -no-restart -logflags=0 -home=/opt/tis-sysvolsync/data` commands.
What could be causing this? Replication is working, but strangely, it seems slower. How long does it take for replication to complete?
Thank you very much for your help.
Eric
question about tissysvol
- WAPT Expert
Hello Eric,
Replication should be almost instantaneous.
There shouldn't be more than one Syncthing process on a domain controller. You can kill them all and restart the service. We need to figure out how the same process can run multiple times in parallel... Are you using the correct systemd configuration to launch it?Eric wrote: ↑September 29, 2018 - 9:32 AM I have a question about replication using the tissyvol script, which used to work fine but seems increasingly slow.
With htop, I get dozens of runs of /opt/tis-sysvolsync/bin/syncthing -no-browser -no-restart -logflags=0 -home=/opt/tis-sysvolsync/data.
What's causing this? Replication is working, but strangely, it seems slower. How long does it take for replication to complete?
