[SOLVED] Issue downloading package via Python script
troublestarter
Registration: September 5, 2018 - 10:30
October 4, 2018 - 2:31 PM
Telegram, here is the download link: https://telegram.org/dl/desktop/win
The script cannot download the executable file.
Here is the relevant code:
def update_package():
    """ You can do a CTRL F9 in pyscripter to update the package """
    import re,requests,urlparse,glob
    url = requests.head('https://telegram.org/dl/desktop/win',proxies={}).headers['Location']
    filename = urlparse.unquote(url.rsplit('/',1)[1])
    if not isfile(filename):
        print('Downloading %s from %s'%(filename,url))
        wget(url,filename)
    exes = glob.glob('*.exe')
    for fn in exes:
        if fn != filename:
            remove_file(fn)
    # updates control version from filename, increment package version.
    control = PackageEntry().load_control_from_wapt ('.')
    control.version = '%s-0'%(re.findall('tsetup(.*)\.exe',filename)[0])
    control.save_control_to_wapt('.')
if __name__ == '__main__':
    update_package()
agauvrit
Registration: Nov 17, 2016 - 10:25
October 4, 2018 - 3:27 PM
In my opinion, it will be simpler to retrieve the installer from the project's GitHub repository, which has this format:
https://github.com/telegramdesktop/tdesktop/releases/download/v1.4.0/tsetup.1.4.0.exe
Retrieving the version number with BeautifulSoup shouldn't be too complicated (and it's a good exercise for learning)
Alexander
troublestarter
October 4, 2018 - 3:45 PM
The previous link seemed better to me because it automatically retrieves the latest version...
This is for the "update" part of the package code.
If I write code with a fixed link, what advice would you give for handling version updates? Should I update the code with the new link?
agauvrit
October 4, 2018 - 5:51 PM
Yes, the link can easily be generated by retrieving the latest version number available on this same page.
For reference, the Rocket.Chat package does essentially the same thing: https://wapt.tranquil.it/package_detail ... 2_all.wapt
    proxy={'http':'http://srvproxy:3128','https':'http://srvproxy:3128'}
    import requests,BeautifulSoup
    import re
    verify=True
    pe = PackageEntry()
    pe.load_control_from_wapt(os.getcwd())
    current_version = pe['version'].split('-',1)[0]
    software_name = "Rocket.Chat"
    version_software_url = "https://github.com/RocketChat/Rocket.Chat.Electron/releases/latest"
    pattern=re.compile(r'version (.*)')
    page = wgets(version_software_url,user_agent='Mozilla/5.0 (Windows NT 6.1; Win64; x64)',proxies=proxy)
    bs = BeautifulSoup.BeautifulSoup(page)
    software_version = str(bs.find('title')).split(' ')[1]
    print "Current %s WAPT package version is : %s" % (software_name,current_version)
    print "Latest %s version available is : %s" % (software_name,software_version)
    if Version(current_version) < Version(software_version):
            print "%s package is not up-to-date, updating" % software_name
            print "Cleanup current exe files"
            for exe in glob.glob('*.exe'):
                remove_file(exe)
            print("Downloading latest version")
            wget('https://github.com/RocketChat/Rocket.Chat.Electron/releases/download/' + software_version + '/rocketchat-setup-' + software_version + '.exe' , 'rocketchat-setup' + software_version + '.exe',proxies=proxy)
            pe.version = software_version + '-0'
            pe.save_control_to_wapt(os.getcwd())
        print("No update needed, package already up to date")
Alexander
troublestarter
October 4, 2018 - 7:02 PM
Thank you. I'll have to try it!
Floflobel
Registration: Oct 15, 2015 - 5:32 p.m.
October 4, 2018 - 7:09 PM
I'd like to add my two cents; personally, we use the GitHub API or parse the link to the latest release. I find it much easier: :)
https://api.github.com/repos/telegramde ... ses/latest
October 4, 2018 - 7:32 PM
Floflobel wrote: ↑Oct 4, 2018 - 7:09 PM I'd like to add my two cents; personally, we use the GitHub API or parse the link to the latest release. I find it much easier. :)
A very good contribution, I wasn't aware of the existence of the API!
agauvrit
October 5, 2018 - 9:56 AM
Awesome !
troublestarter
October 5, 2018 - 5:50 PM
I confirm ...
