[RESOLVED] Adding ACL
Gorenda
Registration: August 9, 2018 - 5:34 PM
October 8, 2018 - 2:34 PM
I need to add the user group: "identified users" with access and write privileges to a directory.
The problem is that I can't see how.
I didn't see anything about it on WAPT.
Using PowerShell is very complicated...
This command works in a command prompt (CMD):
run('cacls.exe "C:\Program Files (x86)\sage1000" /C /E /G "utilisateurs authentifiés:C"')
Except my "é" turns into a "?", so it doesn't register it. I haven't been able to figure out how to make an exhaust on this...
Alternatively, does the "copytree2" command allow the ACLs to be preserved during the copy process?
Do you have a solution for performing this type of maneuver?
Thank you in advance
October 9, 2018 - 7:02 PM
run(ur'cacls.exe "C:\Program Files (x86)\sage1000" /C /E /G "utilisateurs authentifiés":C')
October 10, 2018 - 09:45
Hello Gorenda,
htouvet wrote: Oct 9, 2018 - 7:02 PM
To add to Hubert's answer, I wanted to point out that you should use icacls.exe rather than cacls.exe; cacls.exe is deprecated, and for good reason: it is very buggy.
icacls.exe is not available on winXP, but it can be embedded in the package if needed.
