[RESOLVED] Error on server 1.6
- WAPT Expert
Could it be an antivirus blocking the installation?
No, I even uninstalled it to be sure.
The waptservice service is correctly deleted and recreated during installation, but not the waptserver service.
- WAPT Expert
Can you try rebooting the server?.
Sometimes the waptserver service is checked for deletion but remains (a ghost service)
So after rebooting, you need to try a new installation
Alternatively, can you launch:
c:\wapt\waptpython.exe c:\wapt\waptserver\winsetup.py -ldebug install_waptserver -c c:\wapt\conf\waptserver.ini-
Christophe
- Registration: June 5, 2018 - 8:31 AM
Thanks for the tip, sfonteneau.
I successfully installed version 1.6.
However, when I connect to the server address from a browser, I get:
WAPT server version: 1.6.2.7
WAPT agent version: 1.6.2.7
WAPT Setup version: 1.3.13.0
WAPT Deploy version: 1.6.2.7
Database status: OK (1.6.2.4)
I don't understand why WAPT Setup is still showing as 1.3.13?
- WAPT Expert
If you are using a Windows version of the WAPT server, there is no need to update the waptsetup.exe fileChristophe wrote: ↑Oct 12, 2018 - 2:42 PM Thanks for the tip, sfonteneau.
I don't understand why I still have WAPT Setup at 1.3.13?
Indeed, it's often the server that builds the agent. So it's normal; you can even delete the waptsetup.exe file
Thank you very much, it works for me too thanks to the command.sfonteneau wrote: ↑Oct 12, 2018 - 1:19 PM Can you try rebooting the server?.
Alternatively, can you launch:Code: Select all
- WAPT Expert
Hello Romain,
I'll talk to Hubert about adding a timer and a check in the installer to prevent this from happening.
Thank you for your feedback, I'm closing the topic.
After your feedback, it seems that there is a "race condition" between stopping, deleting, and then recreating the waptserver service (the corresponding python file has been renamed from waptserver/waptserver.py to waptserver/server.py in the nssm conf).Romain wrote: ↑Oct 15, 2018 - 2:30 PMThank you very much, it works for me too thanks to the command.sfonteneau wrote: ↑Oct 12, 2018 - 1:19 PM Can you try rebooting the server?.
I got the same error message with the waptservice not existing… Despite the magic command that works for everyone else, it didn't work for me! Here's the code below:
Do you have any further ideas?
THANKS
C:\Windows\system32>c:\wapt\waptpython.exe c:\wapt\waptserver\winsetup.py -ldebug install_waptserver -c c:\wapt\conf\waptserver.ini
Installing WAPT Server as a service managed by nssm
install waptserver
2019-11-09 16:43:36,674 INFO Register service "WAPTServer" with nssm
2019-11-09 16:43:36,674 INFO running command : "c:\wapt\waptservice\win64\nssm.exe" install "WAPTServer" "c:\wapt\waptpython.exe" "c:\wapt\waptserver\server.py"
2019-11-09 16:43:36,861 INFO Register dependencies for service "WAPTServer" with nssm : WAPTPostgresql
2019-11-09 16:43:36,861 INFO running command : "c:\wapt\waptservice\win64\nssm.exe" set "WAPTServer" DependOnService WAPTPostgresql
File "c:\wapt\waptserver\winsetup.py", line 549, in <module>
install_waptserver_service(options,conf)
File "c:\wapt\waptserver\winsetup.py", line 422, in install_waptserver_service
install_windows_nssm_service('WAPTServer',service_binary,service_parameters,service_logfile,service_dependencies)
File "c:\wapt\waptserver\winsetup.py", line 168, in install_windows_nssm_service
setuphelpers.run(cmd)
File "c:\wapt\setuphelpers.py", line 1068, in run
setuphelpers.CalledProcessErrorOutput: Command '"c:\\wapt\\waptservice\\win64\\nssm.exe" set "WAPTServer" DependOnService WAPTPostgresql' returned non-zero exit status 6.
Output:Impossible d'ouvrir le service!
OpenService(): Le service sp├®cifi├® nÔÇÖexiste pas en tant que service install├®.
WAPTPostgresql: Le service de d├®pendance nÔÇÖexiste pas ou a ├®t├® marqu├® pour suppression.
Erreur ├á l'├®criture du param├¿tre "DependOnService" du service "WAPTServer"!
C:\Windows\system32>THANKS
