creating mobaxterm package
Skarn34
Registration: July 6, 2018 - 10:44
November 13, 2018 - 10:52 AM
Hello everyone,
I need a little help with the Mobaxterm software, which is regularly requested internally.
I use the package creation wizard
    print('installing cefe_-mobaxterm')
    install_msi_if_needed('MobaXterm_installer_11.0.msi')
If I test the installation, I get an error
Output::
  File "C:\Program Files (x86)\wapt\common.py", line 3328, in install_wapt
  File "E:\Depots Wapt\cefe_-mobaxterm-wapt\setup.py", line 8, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3289, in new_func
    return func(*args,**kwargs)
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 3783, in install_msi_if_needed
    run(r'msiexec /norestart /q /i "%s" %s' % (msi,props),accept_returncodes=accept_returncodes,timeout=timeout,pidlist=pidlist)
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 983, in run
CalledProcessErrorOutput: Command 'msiexec /norestart /q /i "MobaXterm_installer_11.0.msi" ' returned non-zero exit status 1603.
Output:
FATAL ERROR : CalledProcessErrorOutput: Command 'msiexec /norestart /q /i "MobaXterm_installer_11.0.msi" ' returned non-zero exit status 1603.
Output:
Exit code:  3
If anyone has already managed to create this package, I would appreciate any help or information ;)
Thank you and have a good day everyone
November 20, 2018 - 11:57
Example with the portable version
https://wapt.tranquil.it/package_detail ... 2_all.wapt:
error 1603 with the MSI is quite generic... you should try installing the MSI manually as a system account to see what it says (using psexec for example).
