[SOLVED] WaptServerPostConf timed out
diab92
Registration: Oct 18, 2018 - 4:27 p.m.
November 14, 2018 - 11:20
WAPTSERVER: 1.6.2.7
OS Server: W2008R2
Hello again,
I am trying to reinstall waptserver on my W2008R2 server, but I am unable to configure it. When I launch the configuration (wapt server configuration screen for Windows), after being prompted to enter and confirm the WAPT server password, I get an error window titled "Waptserverpostconf" which tells me: "Read timed out".
Do you have any ideas to suggest, or should I look for them?
THANKS.
PS: In the list of services of my W2008R2 server, I do not see the WAPTPostgresql service while the WAPTNginx, WAPTServer, WAPTService services are present.
diab92
November 14, 2018 - 1:47 PM
Problem solved.
I uninstalled WAPTServer again and then rebooted.
After that, I manually uninstalled the WAPT directory from the hard drive (a few files remained). Then I tried a clean install and the error did not reappear.
