Is there a maintenance schedule for the TIS packages (https://store.wapt.fr/)?
The latest version of CCleaner is 5.49, while the repository version is 5.44, dating from July.
The software therefore offers updates regularly. Does this mean I need to create a package?
Thank you in advance.
WAPT version 1.5
- Server OS: Linux Debian Stretch
- Administration machine OS: Windows 7
Maintenance frequency of the Tis depot
- kguerineau
- Registration: March 6, 2018 - 4:28 PM
thank you for your feedback. I have just updated the package.
There is no set update schedule for the WAPT store itself. It depends primarily on CVEs, major updates, and also the software we use at Tranquil IT and our managed services clients, hence the regular updates of Firefox, Flash Player, Chrome, LibreOffice... but not CCleaner.
You can update them yourself using PyScripter with the `update_package` function when it exists, or recreate the package including the new executable.
- kguerineau
Hello again,
Just to let you know, I've re-uploaded the tis-ccleaner package with the update-package function working. I removed it this morning because it was no longer functioning (due to a change in the download address).
Next time, you can directly edit the package with PyScripter and then press F9 to start downloading the new version. The control file will update automatically. All
you'll need to do is run the build-upload to send the package to your local repository.
Note that a proxy is specified in the update-package section. You'll need to modify it if necessary.
