Agent update 1.3 --> 1.5
Media40
Registration: Nov 28, 2018 - 10:54
November 28, 2018 - 11:59
after updating WAPT from 1.3 to 1.5, the agents are not updating despite the presence of the update package in the repository after generating the agent via the console. I should also mention that my workstations are not reachable in the console (there's a small clock icon in the reachable column). Furthermore, the "Check for updates" and "Launch installations" buttons are inactive or grayed out. If I try from a workstation, it doesn't see any updates to perform either!
The WAPT web server still indicates on the page that the agent is at version 1.3.
Do you have a solution?
November 28, 2018 - 4:14 PM
Have you followed the documentation?
https://www.wapt.fr/fr/doc/waptserver_u ... e-complete
The migration from 1.3 to 1.6 requires numerous steps.
