SAMBA4 DC configuration problem
Come here to talk about your experience with Samba4, your opinion and your wishes.
titi3822
Registration: Nov 30, 2018 - 10:02
November 30, 2018 - 10:04 AM
I could really use some help. I installed Ubuntu Server 18.04.1 LTS on a Dell PowerEdge R330 with a 10TB RAID 5 disk for a small startup. The goal is to have centralized authentication and storage. Their network is mixed (2 Windows PCs, 3 Linux Mint 19 PCs)
I'm desperately trying to configure a Samba4 DC.
The company's priority is to get a working setup for the Linux machines (Mint 19). I'm struggling a bit with the architecture choice. I've tried SMB mounts on the home directories (pam_mkmount) but it's not working very well. There are quite a few issues and crashes (probably due to the mapping between Unix and Windows permissions, or unsupported filenames...)
If I switch to NFS (3 or 4), I need identical UID/GIDs on all machines in the domain. I can't get a working configuration using RIDs... (I have a huge number of UID/GIDs...)
Ideally, I would have liked to be able to set them directly when the user is created (on the DC) and have them be the same everywhere. In the "backend ad" section, it doesn't work either... I get strange errors.
The worst part is that I can't even get a configuration that allows me to see my AD users on the Ubuntu server (whether I use winbind or sssd).
wbinfo -u does list my users correctly. /etc/nsswitch.conf is correct... but no users are present!
testparm gives me an incomprehensible error:
ERROR: The idmap range for the domain * (tdb) overlaps with the range of XD (ad)!
Here is my Samba configuration:
root@adserver:~# cat /etc/samba/smb.conf
# Global parameters
[global]
	dns forwarder =  8.8.8.8
	netbios name = ADSERVER
	realm = XD.LAN
	server role = active directory domain controller
	idmap_ldb:use rfc2307 = yes
	workgroup = XD
	client signing = yes
	client use spnego = yes
        ntp signd socket directory = /var/lib/samba/ntp_signd
        time server = yes
	wins support = yes
	printing = CUPS
        kerberos method = secrets and keytab
        vfs object = acl_xattr
        map acl inherit = yes
        store dos attributes = yes
        dead time = 0
        lock directory = /var/cache/samba
        registry shares = yes
	idmap config * : backend = tdb
	idmap config * : range = 3000-7999
	idmap config XD : unix_nss_info = yes
	idmap config XD:backend = ad
	idmap config XD:schema_mode = rfc2307
	idmap config XD:range = 10000-999999
	template shell = /bin/bash
	template homedir = /home/%D/%U
[netlogon]
	path = /home/samba_sysvol/xd.lan/scripts
	read only = No
[sysvol]
	read only = No
[users]
	path = /home/samba_users
	read only = No
	force create mode = 0600
	force directory mode = 0700
[print$]
       path = /home/samba_printer_drivers
       read only = no
[printers]
       path = /var/spool/samba
       printable = yes
Thank you so much for your help...
A+
