[SOLVED] Delete multiple files
lowix
Registration: Apr 02, 2017 - 5:59 p.m.
December 3, 2018 - 3:02 PM
Hello community!
I'm trying to delete multiple files based on their extension using the "remove_file" function, and I was wondering if it's possible to use a wildcard character like this:
remove_file(r'C:\Users\Public\Desktop\*.lnk')
Thank you in advance for your reply ;)
December 3, 2018 - 3:10 PM
not directly...
import glob
    for filename in glob.glob(r'C:\Users\Public\Desktop\*.lnk'):
        delete_file(filename)
lowix
December 3, 2018 - 3:59 PM
htouvet wrote: Dec 3, 2018 - 3:10 PM not directly...
import glob
tremendous !
lowix
December 3, 2018 - 4:20 PM
import glob
However, unless I'm mistaken, it's a remove_file and not a delete_file
THANKS
