Deployer waptexit-logo
nawak
Registration: December 12, 2018 - 5:25 PM
December 13, 2018 - 10:53
I wanted to know if there was a way to deploy the logo for Wapt Exit via Wapt?
Thank you for your feedback.
Have a good day
nawak
December 13, 2018 - 4:10 PM
Could this work?
    print("Copie du logo waptexit-logo.png")
    if isdir(makepath(programfiles32,'wapt','templates')):
        if isfile(makepath(programfiles32,'wapt','templates','waptexit-logo.png')):
            print("Le logo existe déjà !")
            filecopyto('waptexit-logo.png',makepath(programfiles32,'wapt','templates'))
        print("Copie du logo impossible le dossier template de WAPT n'existe pas !")
nawak
December 14, 2018 - 2:13 PM
Hello again
    print('Copie du logo waptexit-logo.png')
            print('Le logo existe déjà !')
            print('Le logo a ete copié !')
        print('Copie du logo impossible le dossier template de WAPT n\'éxiste pas !')
The code works, but the accents aren't displaying. Any ideas?
I tried:
 print(ur'Copie du logo impossible le dossier template de WAPT n\'éxiste pas !')
But it doesn't work.
agauvrit
Registration: Nov 17, 2016 - 10:25
December 17, 2018 - 12:30
Solution :
 print(ur"Copie du logo impossible le dossier template de WAPT n\'éxiste pas !")
  • When the string contains one or more apostrophes, enclose it in quotation marks
  • When the string contains one or more quotation marks, enclose it in apostrophes
nawak
December 17, 2018 - 2:36 PM
Thanks for the explanation. If I run the test in PyScripter debug mode, I get this output:
Logo copying is impossible; the WAPT template folder does not exist!
Any ideas?
THANKS
Have a good day!
