[RESOLVED] V 1.6.2.7 Unable to connect to the console via AD
guil.cap
Registration: December 18, 2018 - 11:05 AM
December 18, 2018 - 11:11
Hello everyone !
After trying many times with various settings, I am unable to log in with Active Directory credentials to the WAPT console.
I have a WAPT enterprise license, a Windows 2008 R2 AD server, and I am using WAPT version 1.6.2.7
My .ini file is configured correctly; however, when I launch the console, I am unable to use AD credentials to log in
Here is my ini configuration (I have hidden the details of my domain controller):
wapt_admin_group_dn=CN=waptadmins,OU=Groupes,DC=xxxx,DC=local
ldap_auth_server=srv00.xxxx.local
ldap_auth_base_dn=DC=xxxx,DC=local
ldap_auth_ssl_enabled=false
December 18, 2018 - 1:35 PM
Works at my place
Can you try the following order:
telnet srv00.xxxx.local 389
guil.cap
December 18, 2018 - 1:59 PM
When I run the telnet command I get:
Trying 192.168.1.200...
Connected to srv00.xxx.local
Escape character is '^]'.
Connection closed by foreign host.
December 18, 2018 - 2:03 PM
And ?
telnet srv00.xxxx.local 3268
If that still doesn't work, you have a firewall problem
guil.cap
December 18, 2018 - 2:07 PM
On port 3268:
Connected to srv00.xxxx.local.
December 18, 2018 - 2:15 PM
Your ad seems not to be listening on port 389
In this case, you can modify the file /opt/wapt/waptenterprise/waptserver/auth_module_ad.py
replace on line 77:
ldap_client = ldap.initialize('ldap://%s:389' % dc_name)
by
ldap_client = ldap.initialize('ldap://%s:3268' % dc_name)
You can then restart the wapt service
We will address this issue in the next version
guil.cap
December 18, 2018 - 2:34 PM
However, after the telnet command, I have the impression that the connection to LDAP is working, but the connection to the AD account remains impossible
guil.cap
December 19, 2018 - 09:02
I just did a quick check and it seems that the AD connection is working since on the left of WAPT, I can see the OUs that contain workstations and therefore add packages to the workstations in these OUs (this information may be coming back via local information on the workstations).
vcardon
December 19, 2018 - 9:53 AM
guil.cap wrote: Dec 19, 2018 - 09:02 I can see the OUs that contain workstations and therefore add packages to the workstations in these OUs (this information may be relayed via local information on the workstations)
Indeed, the Organizational Unit information displayed in the Enterprise console is correctly retrieved from the Customer inventory.
AD provides the information to the Clients and the information is then displayed in the console.
Vincent
guil.cap
December 19, 2018 - 11:28
So, my WAPT server is able to communicate with Active Directory, but I don't understand why I can't authenticate with an AD account on the console, even though:
My group is located at: xxxx.local/Groups/waptadmins
In the attributes: CN=waptadmins,OU=Groups,DC=xxxx,DC=local
My AD accounts are indeed present in the group.
I'm a bit stuck on why I can't log in.
