[RESOLVED] V 1.6.2.7 Unable to connect to the console via AD
December 19, 2018 - 12:41
Is port 389 working now?
Verification with:
telnet srv00.xxxx.local 389
Otherwise Make the modification indicated in the previous post above (in the file /opt/wapt/waptenterprise/waptserver/auth_module_ad.py)
guil.cap
Registration: December 18, 2018 - 11:05 AM
December 19, 2018 - 12:44
As mentioned, the console retrieves some information from AD (but authentication fails).
For the command: telnet srv00.xxxx.local 389
Here is the result:
Trying 192.168.1.200...
Connected to srv00.xxxx.local.
Escape character is '^]'.
Connection closed by foreign host.
December 19, 2018 - 1:16 PM
The OUs reported in the console are reported by the workstations (no AD connection).
Seeing the OUs in the console does not necessarily mean the LDAP connection is working.
Port 389 now appears to be available, so you don't need to make the change. Your configuration seems correct.
guil.cap
December 19, 2018 - 1:35 PM
However, when I use my AD login credentials to try to open the console with my domain account, authentication fails.
My account is indeed in the Waptadmins AD group, which is in the correct OU (as indicated in the ini file).
I don't understand what could be blocking it.
guil.cap
December 20, 2018 - 09:01
Is there a system that allows testing the WAPT/AD connection with logs?
December 20, 2018 - 10:53
Good morning
To launch the server in debug mode:
systemctl stop waptserver
/opt/wapt/runwaptserver.sh -ldebug
The server is then started in debug mode (leave your PuTTY window open)
You should see the authentication process
Can you provide us with the file /opt/wapt/conf/waptserver.ini (masking the sensitive information wapt_password, secret_key)?
guil.cap
December 20, 2018 - 11:07
I just tested the debugging, and I got this result:
2018-12-20 11:06:41,414 DEBUG Traceback (most recent call last):
File "/opt/wapt/waptserver/server.py", line 927, in login
raise EWaptAuthenticationFailure('Authentication failed.')
EWaptAuthenticationFailure: Authentication failed.
guil.cap
December 21, 2018 - 7:59 AM
Do you have any idea what could be causing this blockage?
December 21, 2018 - 09:16
guil.cap wrote: Dec 21, 2018 - 07:59 Do you have any idea about this blockage?
The log doesn't mention the LDAP part
guil.cap
December 21, 2018 - 12:01
Here it is:
[options]
server_uuid = a480287a-a79c-11e8-ac90-fe149ee36605
wapt_password = XXXXXXXXXXXXXXXXXXx
allow_unauthenticated_registration = True
secret_key = XXXXXXXXXXXXXXXX
use_kerberos = True
allow_unauthenticated_connect = True
wapt_admin_group_dn = CN=waptadmins,OU=Groups,DC=xxxx,DC=local
ldap_auth_server = srv00.xxxx.local
ldap_auth_base_dn = DC=xxxx,DC=local
ldap_auth_ssl_enabled = False
