Debian update: nginx auth_gss directive unknown
God
Registration: December 14, 2018 - 11:24
December 14, 2018 - 11:32
WAPT version installed: 1.6
- Server OS: Debian 9.6.
Following a Debian update, nginx was updated to version 1.10.3.
The service no longer starts; it doesn't recognize the auth_gss directive in the configuration file:
/etc/nginx/sites-enabled/wapt.conf
. Currently, I've commented out:
# location /add_host_kerberos {
# auth_gss on;
# auth_gss_keytab /etc/nginx/http-krb5.keytab;
# proxy_pass http://127.0.0.1:8080;
How can this be fixed?
God
December 14, 2018 - 12:01
The module /usr/lib/nginx/modules/ngx_http_auth_spnego_module.so had been deleted.
The file /etc/nginx/modules-enabled/50-mod-http-auth-spnego.conf existed but was empty.
I restored everything, uncommented the lines in the config file, and restarted Nginx; everything is working correctly.
Hope this helps someone...
Bye!
TomTomGo
Registration: May 3, 2017 - 3:36 p.m.
December 17, 2018 - 10:03
I have the same problem and after checking the file https://wapt.tranquil.it/debian/wapt-1. ... _amd64.deb I realize that the module is missing from the package (/usr/lib/nginx/modules/ngx_http_auth_spnego_module.so).
How did you solve the problem?
Thanks
God
December 19, 2018 - 1:08 PM
I retrieved it from a backup.
Regards,
James
Registration: Sep 18, 2018 - 4:37 p.m.
December 21, 2018 - 4:17 PM
I have exactly the same problem...
