Migration error from version 1.3.13.0 to 1.6.2.7
filou07
Registration: December 6, 2018 - 3:33 PM
December 6, 2018 - 3:48 PM
I'm migrating from version 13.13.0 to 1.6.2.7. The post-configuration displays an error when migrating to PostgreSQL because a file appears to be in use. Even after rebooting my server and exiting the WAPT agent, the error persists.
My server is running Windows Server 2012 R2 Datacenter 64-bit
Error text:
Error during post-config:
System Error, (OS Code 1):
Fonction incorrecte : Traceback (most recent call last):
 File "C:\wapt\\waptserver\upgrade.py", line 189, in
<module>
comment_mongodb_lines(conf_filename=options.config...
 File "C:\wapt\\waptserver\upgrade.py", line 125, in
  os.rename(conf_filename, '%s.%s' % (conf_filename,
datetime.datetime.today().strftime(%Y%m%d-%H:%M:...
WindowsError: [Error 32] Le processus ne peut pas acc?der
au fichier car le fichier est utilis? par un autre processus
Thank you for your help
filou07
December 10, 2018 - 4:50 PM
Is there only one inspired person?
Thank you
PetApp
Registration: January 9, 2019 - 10:58
January 9, 2019 - 12:37
filou07 wrote: ↑Dec 6, 2018 - 3:48 PM Good morning,
Error text:
<module>
I had the same error!
January 14, 2019 - 8:21 PM
Hello filou07,
filou07 wrote: ↑Dec 6, 2018 - 3:48 PM I'm migrating from version 13.13.0 to 1.6.2.7. The post-configuration displays an error when migrating to PostgreSQL because a file appears to be in use. Even after rebooting my server and exiting the WAPT agent, the error persists.
Error text:
<module>
It seems your update is failing because the upgrade is blocked due to another process having an exclusive lock on the waptserver.ini file. There's no reason why a process should be blocking this file...
Your problem hasn't inspired many people, so I'll first check your antivirus software. Alternatively, you can install Process Explorer [1] (there's a wapt package available) to see which process has a lock on it.
[1] https://docs.microsoft.com/en-us/sysint ... s-explorer
Amiled1981
Registration: Nov 12, 2021 - 8:39 p.m.
November 12, 2021 - 8:47 PM
The contrib program pg_upgrade allows an installation to be migrated in-place from one major PostgreSQL version to the next
