- Server OS (Linux) and version (Stretch)
- Operating system of the administration/package creation machine (Windows 10)
I'm having trouble using iTunes. I followed Apple's silent install method, but the software isn't working properly. When I go into the settings, iTunes crashes, and it doesn't work with my iPhone even though I've installed all the iTunes components.
I wanted to know if any of you have managed to get iTunes working properly.
Here is my script:
uninstallkey = ['{5881B877-CB42-4317-9411-96BA3CA39715}']
Property = get_file_properties('iTunes64Setup.exe')['ProductVersion']
waptdev = 'c:/waptdev/futur-Itunes_x64_PROD-wapt/Setup'
print('installing futur-Itunes')
install_msi_if_needed('AppleApplicationSupport64.msi', min_version='7.2')
install_msi_if_needed('Bonjour64.msi', min_version='3.1.0.1')
install_msi_if_needed('AppleMobileDeviceSupport64.msi', min_version='12.1.0.25')
install_msi_if_needed('AppleSoftwareUpdate.msi')
## install_msi_if_needed('iTunes64.msi',uninstallkeylist='{A9921EE9-86E5-402C-A934-4A8DBAD99E24}')
## install_exe_if_needed('iTunes64Setup.exe', silentflags='/qn /norestart', key='{5881B877-CB42-4317-9411-96BA3CA39715}',min_version='12.9.2.6',killbefore=['iTunes.exe'])
run('start /wait /i iTunes64Setup.exe /qn /norestart')
print('Uninstalling Itunes')
print('Apple Application Support (64 bits)')
run('MsiExec.exe /X {466D00D0-E7DE-47C2-8FE5-54A8009F5850} /quiet')
print('iTunes')
run('MsiExec.exe /X {5881B877-CB42-4317-9411-96BA3CA39715} /quiet')
print('Apple Mobile Device Support')
run('MsiExec.exe /X {5FA8C4BE-8C74-4B9C-9B49-EBF759230189} /quiet')
print('Apple Application Support (32 bits)')
run('MsiExec.exe /X {80B42CAA-28C0-4FBD-A46E-D61F45E2F9FC} /quiet')
print('Apple Software Update')
run('MsiExec.exe /X {A30EA700-5515-48F0-88B0-9E99DC356B88} /quiet')
def update_package():
""" You can do a CTRL F9 in pyscripter to update the package """
import re,requests,urlparse,glob
url = requests.head('https://www.apple.com/itunes/download/win64',proxies={}).headers['Location']
filename = urlparse.unquote(url.rsplit('/',1)[1])
if not isfile(filename):
print('Downloading %s from %s'%(filename,url))
wget(url,filename)
exes = glob.glob('*.exe')
for fn in exes:
if fn != filename:
remove_file(fn)
# change version of package
from waptpackage import PackageEntry
pe = PackageEntry()
pe.load_control_from_wapt(os.getcwd())
pe.version = get_file_properties('iTunes64Setup.exe')['ProductVersion']+'-0'
pe.save_control_to_wapt(os.getcwd())
#Extraction fichier install
run('iTunes64Setup.exe /extract')
if __name__ == '__main__':
update_package()
