I currently have the WAPT agent deployed across my network via waptdeploy using Group Policy.
However, we have to manually assign the default software group we created to each new workstation in the WAPT console.
Is there a way to automatically assign this default group when deploying the default agent?
If so, do you have any idea what syntax to use in the waptdeploy command line?
I've tried the StartPackages option, but without success.
Does anyone have any suggestions?
Thank you very much for your help.
Deploying the agent with a default group
- WAPT Expert
Hello Gauthier,
In the case of the enterprise version, it is possible to create an "Active Directory" group which will apply to all workstations in a default OU.
Indeed, StartPackages should work as you indicated, but there must be a problem, a race condition with the service startup. If you have time to debug, please feel free to send a fix!gauthier_leclercq wrote: ↑Feb 7, 2019 - 4:50 PM I currently have the WAPT agent deployed across my network via waptdeploy using GPO.
However, we have to go into the WAPT console to manually assign the default software group we created to each new workstation.
I've tried the StartPackages option but without success ;(.
Does anyone have any ideas?
