Firefox 60.5.2 added taskbar shortcut
Dylan
Registration: June 9, 2016 - 10:28
March 6, 2019 - 10:19
I would like to add a taskbar shortcut to the Firefox 60.5.2 package after installation.
It seems I need to go to "C:\Users\%USERNAME%\AppData\Roaming\Microsoft\Internet Explorer\Quick Launch\User Pinned\TaskBar" for both Windows 7 and Windows 10 machines.
What would be the correct "create_shortcut" command to include in setup.py?
Thank you in advance.
Dylan
WAPT 1.6.2.7
skoizer
Registration: June 19, 2018 - 4:45 PM
March 28, 2019 - 08:40
the problem with creating a shortcut like this
(C:\Users\%USERNAME%\)
is that you have to copy as many shortcuts as you have users you've created.
What about future users? They won't have them.
Look here: https://docs.microsoft.com/fr-fr/window ... 10-taskbar
vcardon
March 28, 2019 - 5:13 PM
On the contrary, with a "session_setup", it can be done very simply, and it will even work with new users.
See https://www.wapt.fr/fr/doc/wapt-create- ... index.html
Regards.
skoizer
March 29, 2019 - 08:53
Thanks, I didn't know that.
Interesting.
So, if I understand correctly, for this to work, I need to configure the package and add a GPO calling this:
C:\Program Files (x86)\wapt\wapt-get.exe session-setup ALL?
Is that right?
vcardon
March 29, 2019 - 2:33 PM
skoizer wrote: March 29, 2019 - 8:53 AM So if I understand correctly, for this to work, you need to configure the package and add the call to this in a GPO.
If you really want to use a GPO, why not, it's just that you're complicating your life without any obvious benefit.
Take a look at https://store.wapt.fr/store/details-tis ... OD_de.waptThis should give you some inspiration.
Sincerely.
March 29, 2019 - 7:46 PM
skoizer wrote: March 29, 2019 - 8:53 AM Thank you, I didn't know that.
Interesting.
So, if I understand correctly, for this to work, I need to configure the package and add the following to a GPO
: C:\Program Files (x86)\wapt\wapt-get.exe session-setup ALL?
Is that right?
There's no need to create a GPO; during the WAPT installation, a shortcut to the session setup will be automatically created in: C:\ProgramData\Microsoft\Windows\Start Menu\Programs\StartUp
Dylan
April 1, 2019 - 3:37 PM
thank you for your various replies.
Regarding session_setup, I hadn't realized it was possible to create a shortcut in the taskbar; could you perhaps provide an example?
