[SOLVED] Copytree2
Nicolas Halsberghe
Registration: February 15, 2019 - 11:41
March 12, 2019 - 09:09
I created a package that copies portable applications to a folder. The package installation worked perfectly until I added a 600 MB application to copy. The package then returned an error (ERROR-UPGRADE). Is there a timeout I need to add for the package to install correctly? A screenshot of the error is attached.
WAPT version installed: 1.6.2.7.
System: Windows 7
vcardon
August 13, 2019 - 10:43 PM
It's resolved, well done, nothing to add. Vincent
