Error message during app deployment, but deployment successful
markham
August 21, 2015 - 7:49 PM
I get an error message when I force app deployment, even though deployment works normally:
Why, and how do I remove it?
ps: the hidden area represents the IP address of the target machine.
Thank you.
August 24, 2015 - 1:24 PM
the command is being sent to the client, but the console is showing a timeout? Is that correct?
markham
August 24, 2015 - 10:36 PM
Yes, that's right.
August 25, 2015 - 09:22
For testing purposes only, could you disable the client/server firewalls and repeat the test?.
