Multi-repository Sync Problem
Nicolas Halsberghe
Registration: February 15, 2019 - 11:41
April 5, 2019 - 3:49 PM
I'm having a problem with a remote repository. After modifying the packages, the `chown` attribute changes to `Root` instead of `wapt/www-data`. I don't understand where the problem could be coming from, as everything works correctly with three other remote sites.
April 15, 2019 - 8:50 PM
https://www.wapt.fr/fr/doc/wapt-replica ... -syncthing
Can you confirm that it is indeed the waptsync service that started?
And what about User=wapt, which is indicated in the service?
Can you run the command?
id wapt
To see the groups of the Wapt user?
Nicolas Halsberghe
April 30, 2019 - 3:13 PM
The id wapt command gives me this:
uid=107 (wapt) gid=33(www-data) groups=33(www-data)
