[SOLVED] Run a batch or powershell script
Herzas
Registration: Apr 02, 2019 - 11:44
April 16, 2019 - 11:36
In the end, my script had no errors; it was just an indentation issue. Yes, Python is very sensitive to it, and when you discover Wapt and Python on the same day, an extra or missing line break after a semicolon might seem insignificant. But not for Wapt!.
adgm11
Registration: Apr 12, 2022 - 07:00
June 26, 2022 - 01:37
how do I run the batch file only once and prevent it from restarting every time I shut down?
I tried `run_once` but it doesn't work.
Thanks.
June 27, 2022 - 10:45
Hello adgm11,
same as for the other post, please avoid necro-posting and create a new thread. WAPT is evolving rapidly, and it's very likely that the answers will be different compared to 2019... I'm closing this thread.
Regards,
