I'm experiencing strange behavior with my PyScripter installation using Inno Setup.
I have an `install_exe_if_needed` command with the silent flags `/dir="mydirectory" /verysilent /suppressmsgboxes`.
If I leave it as is, the installer crashes immediately.
If I change it to `/verysilent /suppressmsgboxes /dir="mydirectory"`, it installs in... `c:\suppressmsgboxes`.
I apparently have the latest version of PyScripter.
If anyone has any ideas, I'd appreciate it.
Thanks in advance.
[SOLVED] Strange pyscripter behavior
- WAPT Expert
Good evening Arsgunner,
Could you please check the command line in a cmd.exe window to verify that the settings are working correctly? Your installer might not be behaving according to the innosetup specifications. You can also reuse the line in question in a run() function if needed.Arsgunner wrote: ↑May 7, 2019 - 4:56 PM I'm experiencing strange behavior with my PyScripter using an Inno Setup installer.
I have an `install_exe_if_needed` command with `silentflags '/dir="mydirectory" /verysilent /suppressmsgboxes'`.
If I leave it like that, the installer crashes immediately.
If I change it to `/verysilent /suppressmsgboxes /dir="mydirectory"`, then it installs in... `c:\suppressmsgboxes`.
