Hello everyone,
I followed the documentation to install my server on version 1.7.3.5, I also added the TIS repository, and then I started importing packages.
For the past few days, I haven't been able to install any packages on any machine. Communication between the client and the server is working fine. When I run a package update from my client, I see the information appear on the server side. However, the host icon remains green instead of displaying the triangle indicating that updates are available.
I thought it might be an antivirus issue, so I added the recommended folders and files from the FAQ, but no, that's not the problem.
Has anyone else encountered this issue? Do you have any idea what might be causing it?
Unable to install packages
I'll answer myself if it can help some people.
After analyzing the logs, I realized it was a certificate issue.
For the moment I will therefore use the test machine for administration and I will see about migrating the certificates to the secure machine if that is possible.
I installed my administration console on a test machine, I wanted to migrate the certificates from this machine to the second (more secure) one, but I must have missed something.wapt invalid token: Signature expired
Looks more like a station clock that's drifted... check the NTP
