Wapt API for web interface
Calvibald
Registration: May 20, 2019 - 4:16 p.m.
May 20, 2019 - 4:26 PM
Hello, good evening.
Here's my problem: I'm currently creating a custom web interface for WAPT. This interface is intended for trainers in a training center, and I want to allow them to access a menu displaying the rooms they manage. This menu should lead to information about each room, as well as all the computers available in that room.
My problem is that, lacking documentation, I'm having trouble understanding how the API works, and I wanted to know if it's possible to assign packages to a group via the API. And if so, how? Is it possible to do the same for individual computers?
WAPT version: 1.5
Server OS: CentOS 7
Client OS: Windows 7
- JEANTET Joey, development student
May 21, 2019 - 08:50
the WAPT API communicates in JSON and allows you to retrieve the same information as the console.
Here are a few examples:
https://admin:password@srvwapt.mydomain ... imit=10000
https://admin:password@srvwapt.mydomain ... /v1/groups
With the API, you can retrieve information, upload a package, delete a package, launch Wake-on-LAN commands, etc.
However, you cannot create packages with the API, and therefore, to answer your question, you cannot assign packages to a group or a computer using the API.
Currently, when you assign packages to a group or a computer, the console builds the package locally on the machine and then sends it to the WAPT server with a POST request:
https://admin:password@srvwapt.mydomain ... d_packages.
This approach was chosen to prevent the WAPT repository from becoming a sensitive asset.
Indeed, the WAPT server does not possess the private key; it only acts as a relay. Only the holder of the private key can perform actions on the workstations.
Calvibald
May 21, 2019 - 09:01
Okay, thanks for the quick reply, I should be able to manage with that, thanks!
Calvibald
May 21, 2019 - 11:27
Hello again, my problem is still ongoing. I considered directly modifying the database with PHP or executing Linux commands from within it. The problem is that the changes to the database are apparently not being applied on the client side. And I can't find any server-side commands. Is there a possible solution? Could I use a script already present on the server? Or a procedure?
May 21, 2019 - 11:58
As I already said, it's not in the database, no need to modify it! ... :roll:
These are flat files located in /var/www/wapt/
https://doc.ad.tranquil.it/fr/doc/wapt- ... positories
Calvibald
May 21, 2019 - 12:09
I understood the concept, but my problem is:
Is there a server command that allows adding a package to a user for installation?
For example :
wapt-add-usrpackage sta5803693 test-java8
and thus obtain it here
This function would be used on a web panel with a user system
Sorry for asking so many odd questions
May 22, 2019 - 09:21
Here's a sample code for free:
from waptpackage import PackageEntry,WaptLocalRepo
from waptcrypto import SSLCABundle,SSLPrivateKey,SSLCertificate
uuid_machine = 'BEDBD700-7277-11E3-AAA8-F44D30629A99'
removedepend=["toto"]
adddepend=["test","test2"]
certpub="/root/mykey.crt"
privatekey="/root/mykey.pem"
passwordkey='password'
ca_bundle = SSLCABundle()
signers_bundle = SSLCABundle()
signers_bundle.add_certificates_from_pem(pem_filename=certpub)
key = SSLPrivateKey(privatekey)
pe = PackageEntry(waptfile = "/var/www/wapt-host/%s.wapt" % uuid_machine)
depends = pe.depends.split(',')
for dep in adddepend:
    if not dep in depends:
        depends.append(dep)
for dep in removedepend:
    if dep in depends:
        depends.remove(dep)
pe.depends = ','.join(depends)
pe.inc_build()
pe.sign_package(private_key=key,certificate = signers_bundle.certificates(),private_key_password=passwordkey)
sudo -u wapt PYTHONPATH=/opt/wapt PYTHONHOME=/opt/wapt /opt/wapt/bin/python /opt/wapt/test.py
I obviously advise against this technique since it requires the key to be on the server... :?
Calvibald
May 22, 2019 - 09:33
Thanks for the free code, it's helpful!
If I manage to finish the code on time, I'll publish it somewhere on the forum as open source.
Have a good rest of the day!
Calvibald
June 4, 2019 - 2:51 PM
Hello, hello! It's me again. I've finished the web panel I intended to make (it's available on the forum) but I'm having a problem with the Python script.
despite the (private_key_password=passwordkey) option in sign_package() the script systematically asks for the password.
which jeopardizes everything.
I took a look at waptpackage.py to find the method and I noticed password_callback=passwordkey which also does not work.
Did I miss something? (The Python code is the same as above.).
June 5, 2019 - 09:15
I admit I haven't tried using a password on the key.
I'll have to test it more thoroughly; there might be a problem.
