[RESOLVED] Package in the repository but not available
joel.montelimard
Registration: August 29, 2017 - 10:48
June 25, 2019 - 5:19 PM
I'm setting up a new server and I'm having some trouble.
I want to install Scribus on a client machine, and it requires Ghostscript as a dependency. So I added both Scribus and Ghostscript to my repository (see attached repository.jpg)
, but when I try to add a package to the machine, Ghostscript isn't available (see attached machine.jpg)... and therefore the installation isn't possible (see attached inventory.jpg).
Any ideas?
Wapt server 1.7.4.6077,
Windows Server 2008 R2.
Test PC for package installation: Windows 7 x64
June 25, 2019 - 10:54 PM
GhostScript is x86 in your repository, not x64, that's definitely it
joel.montelimard
June 26, 2019 - 08:28
Yes, I saw that... however, that's the version available on the Wapt store
joel.montelimard
June 26, 2019 - 11:36
Problem solved... I edited the package in question and put "all" in "architecture"... this generated a new package which is correctly visible and satisfies the dependencies
June 26, 2019 - 12:36
The store issue is resolved ;)
