[SOLVED] WAPT console installation problem following update from 1.6 to 1.7
celine18
Registration: Oct 03, 2018 - 3:14 p.m.
July 3, 2019 - 11:01
Debian Stretch Server
, WAPT Server version: 1.7.4,
WAPT Agent version: 1.6.2.7,
WAPT Setup version: 1.7.4.6143,
WAPT Deploy version: 1.7.4.6143,
Database status: OK (1.7.4.0)
, Console: Windows 10.
We are migrating from version 1.6.2.7 to 1.7.4. The server updated successfully, but when installing the console by downloading the file from https://serveurwapt/, the waptsetup version is still 1.6.2.7. We cannot get version 1.7.4. Why is this?
Do we need to re-enter a command on the server to generate it?
Consequently, we also cannot create the agent with the correct version from the console.
Céline
July 3, 2019 - 12:30
There might be a problem with a proxy cache or browser cache.
If you're unsure, you can download waptsetup.exe from our website: https://wapt.tranquil.it/wapt/releases/ ... tsetup.exe
celine18
July 3, 2019 - 3:25 PM
Thank you for your feedback.
The problem was indeed with the browser cache.
I was able to update the console and create the new agent.
Céline
