[SOLVED] Package remove metro apps
Mathieu
Registration: August 18, 2016 - 10:24
July 14, 2019 - 10:18
I've recently been having a problem with a Remove Metro apps package. It used to work perfectly, but after a few installations, the package is showing an error, even though I haven't touched the script since the package was put into production
Here is the message:
Starting the debloating process...Trying to remove Microsoft.BingFinance
NoneTrying to remove Microsoft.BingNews
NoneTrying to remove Microsoft.BingSports
NoneTrying to remove Microsoft.BingWeather
NoneTrying to remove Microsoft.Getstarted
NoneTrying to remove Microsoft.XboxApp
NoneTrying to remove Microsoft.ZuneMusic
NoneTrying to remove Microsoft.ZuneVideo
NoneTrying to remove Microsoft.MinecraftUWP
NoneTrying to remove Microsoft.BingFoodAndDrink
NoneTrying to remove Microsoft.BingTravel
NoneTrying to remove Microsoft.BingHealthAndFitness
NoneTrying to remove Microsoft.WindowsReadingList
NoneTrying to remove Flipboard.Flipboard
NoneTrying to remove ShazamEntertainmentLtd.Shazam
NoneTrying to remove king.com.CandyCrushSaga
NoneTrying to remove king.com.CandyCrushSodaSaga
NoneTrying to remove king.com.*
NoneTrying to remove ClearChannelRadioDigital.iHeartRadio
NoneTrying to remove 4DF9E0F8.Netflix
NoneTrying to remove 6Wunderkinder.Wunderlist
NoneTrying to remove Drawboard.DrawboardPDF
NoneTrying to remove 2FE3CB00.PicsArt-PhotoStudio
NoneTrying to remove D52A8D61.FarmVille2CountryEscape
NoneTrying to remove TuneIn.TuneInRadio
NoneTrying to remove TheNewYorkTimes.NYTCrossword
NoneTrying to remove 828B5831.HiddenCityMysteryofShadow
NoneTrying to remove Microsoft.Advertising.Xaml
NonePreviously removed by wapt :
Remaining metro apps ;) : Traceback (most recent call last):
  File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
  File "c:\windows\temp\waptxq1txp\setup.py", line 102, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4399, in run_powershell
    raise ValueError(u'%s returned non json data:\n%s' % (cmd,result))
UnicodeDecodeError: 'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128)
'ascii' codec can't decode byte 0x8a in position 47313: ordinal not in range(128) : faulty string is ''[\r\n    {\r\n        "Name":  "1527c705-839a-4832-9118-54d4Bd6a0c89",\r\n        "Publisher":  "CN=Microsoft Windows, O=Microsoft Corporation, L=Redmond, S=Washington, C=US",\r\n        "PublisherId":  "cw5n1h2txyewy",\r\n        "Architecture":  11,\r\n        "ResourceId":  "neutral",\r\n        "Version":  "10.0.16299.15",\r\n        "PackageFamilyName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_cw5n1h2txyewy",\r\n        "PackageFullName":  "1527c705-839a-4832-9118-54d4Bd6a0c89_10.0.16299.15_neutral_neutral_cw5n1h2txyewy",\r\n        "InstallLocation":  "C:\\\\Windows\\\\SystemApps\\\\Microsoft.Windows.FilePicker_cw5n1h2txyewy",\r\n        "IsFramework":  false,\r\n        "PackageUserInformation":  [\r\n                                       "S-1-5-21-485133025-386941804-4221807023-500 [Administrateur]: Installed",\r\n
I had to cut it, but it continues with all the apps that are in the script.
I don't understand why the script suddenly started malfunctioning.
Thank you for your help
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
July 19, 2019 - 7:08 PM
Hello Mathieu,
Mathieu wrote: ↑July 14, 2019 - 10:18 AM I've recently had a problem with a Remove Metro apps package. It used to work perfectly, but after a few installations, the package is showing an error, even though I haven't touched the script since the package was put into production.
Which version of WAPT, which OS version?
Mathieu wrote: ↑July 14, 2019 - 10:18 Here is the message:
Machines also have their mood swings, their little quirks, etc. Each Windows update can be an opportunity to discover new behaviors and new anomalies :-) .
In this case, the PowerShell script returns a JSON file with an unexpected encoding. It seems the JSON blob must have been truncated, right?
Denis Cardon
Mathieu
July 22, 2019 - 2:10 PM
Sorry, I forgot to mention it
- WAPT 1.7.4.6143 Enterprise
- Debian 9.9.
All our machines have the same version of Windows 10, 1709.
Updates are deployed via WSUS, so as far as the OS is concerned, the machines are identical.
Regarding the "JSON Blob," I don't know anything about it; I haven't touched it.
- Debian 9.9
July 25, 2019 - 11:12
It would be interesting to see what's wrong with the PowerShell release...
in the package at the end of the install() procedure
replace
    print(u'Remaining metro apps ;) : ')
    print(u'\n'.join(sorted(u'"%(Name)s", # (%(Version)s)",' % app for app in run_powershell('Get-AppxPackage -AllUsers'))))
by
    print(repr(run_powershell('Get-AppxPackage -AllUsers',output_format='txt')))
And can you post the result of an installation on a machine where it's causing problems?
Mathieu
July 30, 2019 - 5:46 PM
I think there was a problem; I did replace the lines correctly
  File "c:\waptdev\futur-OptionW10_remove_metroapps_PROD-wapt\setup.py", line 104, in install
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4384, in run_powershell
    raise CalledProcessErrorOutput(e.returncode,cmd,e.output)
CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:?????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
FATAL ERROR : CalledProcessErrorOutput: Command u'Get-AppxPackage -AllUsers' returned non-zero exit status -196608.
Output:…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾†ªÿ†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ªÆøÿ‘¾Ý‘­œ‘?¸Æûý‡øÿƒïÿ‘??‡?ý‘«¸ƒ?©‡?¬‡?¾‘¾ü‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«?‘«?‘«õƒ??ƒæ?‘«?‡­?‡?¸ƒ??ƒæ?‡??†æ­ƒæ?‡??†æ­†ªÿ„÷ð†?î‘«ý‘¾Ý‘?ªƒ??ƒæ?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…æ?ƒ??ƒ?ÿ†ªÿ„Ïð‡?©‡?æ‘«?‘æý‡?­‡ªÿ‘??‡?÷‡øÿ†ÿÿ„ñ?†æ«†ªÿ„¬ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï†?¯‡­¾ƒ?ïƒ?¬„æ?‡æ?…æ?ƒ??ƒ?ÿ†ªÿ†?ð‘û¸‘«Ï†?ú‡¾ï‘?ªÆøÿ‡?ü‘ñûÆû¾ƒ??ƒæ?‘û?‘«œ‘?Ï„?Ï‘æî‘?ð‘?©Æøÿ‘«Ÿ‘æð‘û­‘?Ï‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿÆ÷ï…æ?ƒ??ƒ?ÿ†ªÿ„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ðÆøÿ‘­œŠñ­‘?©†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘¾?‘?ªÆøÿ‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ÆûýÆøÿ‡?­‡?õ‘?ð‡?©Æûüƒ??ƒæ?‡­?‘?¾‡?æ‘«¸†?©‘ñî‘?¸ƒ?û†?¬‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†ïó…ù?ƒ?ÿƒ?ÿƒæ?‘«Ÿ‘æð‘û­ƒ?σ?¯ƒ?ðƒ?¬‘?¬‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸Æûÿ‘?ð‘?ýƒ?ü‡?¬‘?­‘?ª‡?­‘?ÿ‘?õ‘?ý‘ææ‘û¾‡?ï†ïó…ù?ƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?ÿƒ?¬‘?¬‘?ù‘§?Æû¾†ªÿ†?¬‡?­‘æ­‡??‘?ýƒ?ü‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?φïó‡ïÿ†ïÿ…ù?…ù?‘«?‘?ú†?ý‘?ù‘ñªƒû?‡­¾†æ¾ƒïÿ‘??‡?ª‡øÿƒïÿƒ?¨ƒ?¬Æ¬î…ù?…ù?†?ð„??‘ûî‘«ü‘?ª‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‘­Ÿ‡?­‘?õ‘øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘?Ï‘?ÿ‘ûî‘«ü‘?ª†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª‡?ü‘??‘?¸Š?¸ƒ?©‘«?‡?æ‘?ÿŠ?ý‡?¾‡?ÿ…橃??ƒ?ÿ‘?ÿ‘?¸‘¾ù‡?¾‘?ÿƒ?¾‘«œ‡?©‘ñîƒñ¾‡?ÿ‘¾ï‘¾ª‘?üƒ?§‡­?‘«ø‡?ý„?ð‘ûî‘«ü‘?ª‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘??‡?ý‘«¸…橃??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿƒ?­‘?ô‡?ý‘«¸ƒ?©‡?ü‘??‘?¸Š?¸ƒ?¾‘?φ?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª…ïÿƒ??ƒ?ÿ„?ÿ‡?©‘?ýƒ?§‘ûæ‘÷ÿ‘ææ‡??ƒ?î‘?χ?ÿ‡?¾‘¾ü‘ûî‘?ÿ‘?ôƒ?œ‘?ª‡?ÿ‡?­‘æ­‡??‘?ýƒ?ª‘?ïƒ?ª‡?ñƒ?¾ƒ?©‡?ð‡?¾‘¾ü‘ûîÆ?ÿÆ?©ˆ¬ÿ…ï©…ï?ƒï?‘«?‘«?‘«õ…ù?ƒ?ÿƒ?ÿ‘??‡?ü‘?æ‘øÿƒ?­‘?½‘û©Š¸¸‘?ý‘?ÿƒ?¾‘«œ‡¾ø‘¾ý‘­õƒ?ï‡?­‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‘«?‡­?‡?¸…ù?ƒ?ÿƒ?ÿ‘??‡?ÿƒ?¾‘?Ý‘æýƒ?¾‘?øƒ?ü‡?­Š¸ýƒ?üƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?σ?ü‘«œ‘æð‘û­‘?σ?ü‘?Ï‘?ÿ‘ô?‡?­‘?ý‘?õ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ý‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾Š?ÿ‘øÿ‘?õ‘?¸ƒ?¾ƒ?Ï‘ûæ‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒûÏ…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘«ª‡?¸‘ûî‘?©‘?ð‡?©‘ïÿ‘ûî‡?î‡?ù‘?¾ƒ?φ?ù„??ƒ?¸‡?¾ƒ?ï‡?æ‘ñ¸‡?¸ƒ??‘?øƒ?ýŠ?Ï‘?݇?æ…ï©…ï?ƒï?‡??…æ­ƒ??ƒ?ÿ„?ÿ‘ô?‡?­‘?ýƒ?ýƒ?ª‘û¸‘?ï‡?ýŠ?ý‘?ï‡?æ‘?ÿƒ?¾‘«œ‘æð‘û­‘?σ?üƒ??ƒ?ª‘¾­‘?Ï‘?ÿ‡?õƒ?©‘ñœ‘¾î‘«ü‘û©‘澑û¾ƒ?ï‡?ð‡?ª‡?¸‡?ù‘?¾ƒûÏ…ù?…ù?„÷ð†?î‘«ý‘¾Ý‘?ª…ù?ƒ?ÿƒ?ÿ‘??‘?ÿ‘?ù‘?ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‘«ý‘¾Ýƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…ï©…ï?ƒï?‘«?„¾©‡?©‡?¾‘?­‘¾ï‘?ô…ù?ƒ?ÿƒ?ÿƒ??‘?­‘¾Ý‘­œƒ?¾‘?øƒ?üƒ?Ï‘û¸‘¾ô‘?ï‘Ïÿ‡?©‡?¾‘?­‘¾ï‘?ô‡?ÿ‡?îƒ?ýƒ?ª‡?æ‘ñ¸‡?¸‡?­‡?¾ƒûý…ù?…ù?„Ïð‡?©‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‡?œ‡?¸‘øÿƒ?¾‘«Ý‘æý‡?­‘?ÿ‡?¾‘?ÿ‘ûîŠ?©‡?¾‘?ÿ‡?©‡¾î‘??ƒ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?©‘??ƒ?ü‘?ô‘?ª‡?æ…æüƒ??ƒ?ÿ‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‡??‡?ï‡?æ‘«?‘æý‡?­…ù?ƒ?ÿƒ?ÿŠ??‘?ï‘æý‘û¸ƒ?¾‘?ª‘ïÿ‡??‘«ù‘?Ï‘?ÿƒ?¾‘¾ð‘?ü‘?ÿƒ?©‘«Ý‘æýƒ?¾‘?Ï‘øÿƒ?­‘«ü‡?ý‘?¸‘?ÿƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…暑??ƒ?ÿ„øÿ‡?¾‡?ÿ‘ñ­‡?¾‡?ý‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûîƒ?ïƒ?©‘??‡?÷ˆ¬ÿƒÿÿ‘­œŠñ­‘?©ƒ?ü‘?χ?ÿ‡­¾‘?ïƒ?¸‡?îˆ÷ÿ†ÿÿ„ñ?ˆ¬ÿƒÿÿ‘«Ý‘æý‡?­„?ÿ„¾?„æ?ƒ??Š?ü‘¾ý‘ñ­‡?¸ƒÝ?…ï©…ï?ƒï?‘¾?‘?©‡?î‡??‘ñû…澃??ƒ?ÿ„?ÿ‘??‘û¸‡?¸‘øÿƒ?¾‡?ü‘ñûƒ?¾‘?Ï‘?ÿ‘û¾‡??‘?ý‡?ÿ‡?æ„÷ÿ‡?î‘?ðƒñª„ïÿ‘û¸‘渇¸¸‘?¾ƒ?ª‘??‘¾÷‘¾ð‘?§ƒ?χ?î„ÿÿ‘?¸‘?σû©…ù?…ù?„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿ‘?œ‡?¾‘?ï‡?ÿ‘?©‡?ÿ‡?¾‘¾ü‘ûî‘?ÿƒ?¾‘­œŠñ­‘?©‘?ÿ‘?î‘??‘?ÿƒ?©‘?½‘?üÆ?ÿƒ?ïƒ?Ï‘ûæƒ?¾‘«œ‘æð‘û­‘?σ?©‡??‘ñ¸‡?¸‡¸¾…ù?ƒ?ÿƒ?ÿ‘?œ‡?ÿ‡?­‘æ­‡??‘?ý‡?ÿ‡?îƒ?ý‘û¾‘«ô‘?ûƒ?ý‘?σ?ü‘«œ‘æð‘û­‘?σ?üƒ??‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘÷ÿ‘??‡?¾‘¾ü‘?ï‡?©…ù?ƒ?ÿƒ?ÿ‘?σ?ü‡?õ‘ñ¸‘?ª‘?ð‡?ï‘?ÿ‘æî‘ñø‡­¾‡?¾‘¬ÿƒ?æ‘?σ?ü‘?­‘«œ‘?ª‘?σûü…ù?…ù?„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð…ù?ƒ?ÿƒ?ÿ‡??‘??‘?¸‘?¸‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿƒ?¾‘«œ‘?©‘?¸‡?æ‡?­‘«¸ƒ?©‘?χ?©‘øÿ‡?¾‘?æƒ?ª‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª‘?ÿ‡?ü‘?ÿŠ?÷‡?œŠ?ï…暑??ƒ?ÿ„Ïÿƒ?ª‘?ø‡?æ‡?ÿ‘?õ‘¾õƒ?ý‘?χ?ÿ‡?îƒ?ï‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‘?ÿ‡?©‘?¾‡?¸‡?ïƒ??‡?üƒ?ý‘?ª‘ïÿ‘?­‘¾ù‘?©‘øÿ‘?î‘ñ­ƒñ¾‘÷ÿ‡?î‘æ­‘?ð‡?©‘øÿ‡?¾…ù?ƒ?ÿƒ?ÿ‘«ø‘û¸‡?ï‘?ÿƒ?¾‘?ï‘æý‘û¸‘¾­‘«üƒ?©ƒ??‘¾Ï‡?ü‘û­‘?œ‡?ÿ‡?­‘?ÿ‘??‡?­ƒ??‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñªƒ?ª‡?î‡?ÿƒ?©‘«ø‘û¸ƒ?ï‘?χ?ÿ‡?¾‘¾ð‘?©‡?¸‘ûî‡?ÿ‡?¾‘«ü‘û©‘ñ­‡?¸…ô?ƒ??ƒ?ÿ‘?ÿ‡?îƒ??‘?Ï‘?ÿ‡?­‘?­‡?¸‡??‡?ÿŠ?ø‘¾œ‘¾Ý‡?ñ‡?¾‘?ÿƒ?æ‚?ý‘?ª‡?ÿ‘¾ï‘¾ª‘?ü‘?ï‡?æ…暑??ƒ?ÿ…ïÿƒï?‘¾?‘?ª…ù?ƒ?ÿƒ?ÿ‡­?‘??‡?æƒ?¾‘?ª‡?ÿ‡?œ‡?¸ƒ?ï‡?ü‘??‘?¸Š?¸‘?ÿ‘û­ƒ?üƒ?ª‡??‘û¾‡?σ?¾‘«ª‘?œ‘?ªƒÿÿ‡?­‘?¾ˆ÷ÿ‘?ÿ‡?î‡?ð‡?î‘?ý‘û¸ƒ?õƒÝîƒ?ª‘?χ?ÿ‡?î‘?ï‡?ÿ‘?æ‘øÿ‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‘ûî‡?œ‘«¸‡?©‘?ÿƒ?ï‘?ô‘¾ý‘?­‘?ªƒ?ü‡?œŠ??‡?¾‡?ÿ‡?­‘øÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾î‘û¾ƒ?χ?ü‘ûî‘?¸‘?ªƒ?ü‘?χ?©‘øÿƒ?­…ù?ƒ?ÿƒ?ÿ‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ôƒ?©‘û?‡?¾‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒ?ï‡?¾‘øÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡??‘û¾‡?ï‘ñ¾ƒûü…ïÿƒ??ƒ?ÿ„øÿƒ?¾‘¾Ý‘­œ‘?¸ƒ?ý‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾‡?ÿ‡?­‘æ­‡??‘?ý‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒñ¾‘?ÿ‡?­‡?ÿ‡?îƒ?ü‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾…ïÿƒ??ƒ?ÿ‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘÷ÿ‘æî‘?ÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾‘¾?‘?ª‡?ÿ‘ûîƒ?ï‘û¸‘?ï‡?ýŠ?ýŠ?ï…æüƒ??ƒ?ÿ‘?ÿ‘æî‘?ðŠ?ÿ‘?ï‡?©‘øÿƒ?¾‘­œ‘澑û¸‘?ÿ‘?õ‘?œ‡??‘?ÿƒ?摾ݑ­œ‘?¸ƒ?ý‘?χ?ÿ‡?œ‡?¸ƒñï‡?ÿ‘¾æ‘¾ô‘?ÿ‡?¾‡?ÿ‡?­‘æ­‡??‘?ýƒ?ü‡?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?„?ð‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ…ù?ƒ?ÿƒ?ÿŠ??‘¾Ý‘¾©ƒ?ï‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî‡?ÿ‡?­‘?ÿ‘??‡?­ƒ?ï‘?Ï‘øÿƒ?­‘?ü‡?ü‘«¸ƒ?©‘?­‘¾ï‘?ô‘?ÿƒ?ïƒ?ª‘û¾‘?ý‘¾õ‡?ü‘?ý…ïÿƒ??ƒ?ÿ‘?ÿ‘û­ƒ?ü‘?ª‡?ÿ‡?­‘?¸‘ñ½ƒ?¾ƒ?Ï‘û¾‘¾ô‘«ý‘û©‘澑û¾ƒ?ï‘?χ?©†?§„??‘?÷‡?œ‘¾ï‘ûî‘«?‘¾ª‡¾œ‡??‘?¾‡?¾‘û¾‘?œƒ?©…ù?ƒ?ÿƒ?ÿ‘?Ÿ‡?ÿ‡?­‘æ­‡??‘?ý‘÷ÿƒ?¾‘«ð‘¾Ï‘¾Ýƒ?¾‘?øƒ?ü‘?ª‡?ÿ‡?ï‡?­‘??‘?¸‘?ÿ‘?õŠ?÷‡?œ‘¾ï‘ûî†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª…ù?ƒ?ÿƒ?ÿŠ?Ï‘¾Ý‘¾©ƒ?¾‘?χ?©‘øÿƒ?¾‘??‘¾õ‡?ü‘?ý…ï©…ï?ƒï?‘«Ÿ‘æð‘û­…æÏƒ??ƒ?ÿ„?ÿŠ?÷‡?œ‘?ï‘øÿ‡?¾‘?ÿ‘æî‘?ð‘?©‡?¾‡?ÿŠ?ø‘¾œ‘¾Ý‘??ƒ?ü‘?ùƒ?ï‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾Š?ÿ‘?ô‡?©‘?æ‡?ªƒ?¸‘«œ‘æðƒ?¾‘¾ü‘?ÿ‘ñª‡?¾Š?ÿ‘?ï‘?¸‡?©…ù?ƒ?ÿƒ?ÿ‘û¾‡?ï‘??ƒ?ü‘?χ?©‘øÿ‘Ïõ‡?©‡?¸ƒ?¾‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿ‘¾æƒ?ü‘?ü‘?ÿ‡?¾‘?ðƒ?ª‘?ü‘?æ‡?ÿƒ?¸…ù?ƒ?ÿƒ?ÿ‘«?‡­?‡?¸‘?ÿ‡?ü‡?ÿŠ?ø‘¾œ‘¾Ýƒ§?„øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘?ø‡?æŠÿÿ‡?ïƒ?¾ƒ?©ƒ?ðƒýî‡?ÿ‘?©‘?ÿ‘?ù‘§?ƒ?¾‡?î‡?ÿ…橃??ƒ?ÿ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒûï…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ïƒ?©ƒ?ðƒýî‘øÿƒ?¾‘?ï‡?÷ƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿ‡?ü‘øÿƒ?æ‘?χ?©…ù?ƒ?ÿƒ?ÿƒ?ª‘û¾‡?ï‘??‡?ÿ‘?ï‘?©‡?­ƒûÏ…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæ‘?ÿ‘«ªƒ?œ‘?χ?ÿ‡?œ‡?¸ƒñï‘?ÿ‘ñ¾‘¾æ‘?ðƒ?¸‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘ñø‘?­…ô?ƒ??ƒ?ÿ‘?ÿ‡?©‘?ý‘?ÿ‘?œ‘ñî‘?­‡?¾ƒÿÿ‡æ¯ƒ÷¸†?ÿ‡?îƒ?ü‘«ø‡?懸¾‡?ÿŠ?ø‘¾œ‘¾Ý‡?¾‡?ÿƒ?©‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘¾©‡?ñ‘澑û¾…æïƒ??ƒ?ÿ‘øÿ‡?î‡?ü‘?æ‡?ÿ‡?îƒ?ü‡­¾‘??‡?懸¾†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª‡­¾ƒ?¾‘?χ?©†?ÿ‘û¸‘«Ï‡?ú†?ÿ‡?î‡?¾‘­?‘ñ¾ƒûª„øÿ‡?¾‡?ÿ‡??‘ñæ‘?ï‡?ï‘?ÿƒ?æ‘ñ½‘?î‘?ÿƒ?¾‘?ü‘¾ý‡?ø‡?ÿ‘ûîƒ?ï‘?ý‡?©‡¾î‡??Š?ÿ‘øÿ‘Ïõ‡?©‡?¾‡?ø‡??‡?¾ƒ?ý‘?Ï‘?ÿ‘æî‘?ð‘?©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ý‡?©‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï†ÿÿ„ñ?‘?ÿ‡??‡??‘?¸‘¾ªŠ?üƒ?ü‡?¾‘÷ÿ‘ûî‡?ÿ‡?­‡?ÿ‡?îƒ?ü‘«Ý‘æýƒ?¾ƒ?Ï‘?î‘?¦‡?ï‘?ÿ‡?œ‘?¸ƒûü…ù?…ù?ƒ?ÿƒ?ÿ‘¾?‘øÿƒ?­‘?ô‘?ª‡?æ‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©ƒ?ª‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«Ï‡?¸Šÿÿ‡?ïƒ?¾‘?ª‘?ÿ‡?¾‘¾©‡?¾…ù?ƒ?ÿƒ?ÿ‘?ø‘?ýЏð‡?ïƒ?¾‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?σ?ª‘?œƒ?ý‘?ªƒ?ü‘?œ‘?ý‡?œ‡??‡?¾‘?ÿ‡?©Š?ýƒ?ü‡?­Š¸ýƒ?ü‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«ü‡?©…ù?ƒ?ÿƒ?ÿ‘û¸‘?ï‡?ýŠ?ýŠ?ïƒ?ü‘«œ‘æðƒ?¾‡?­‡?õ‘?ð‡?©ƒ?ü‘?Ï‘?ÿ‘æî‘?ð‘?©ƒû¾…ù?…ù?ƒ?ÿƒ?ÿ‘«?‡?æŠ?ÿ‡?œ‡?¸ƒ?¾‘ûæƒ?¾‘­œŠñ­‘?©‡?ÿ‘¾æ‘?ÿŠ?÷‡?œ‘?ï‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘¾?‘?©‡?îƒ?ü‘«?‘?ú†?ý‘?ù‘ñª…廙??ƒ?ÿ‡?ÿ‘¾ï‘¾ª‘?üƒ?§‘?ª‘?ÿ‡?î‘?ðƒ?ï…ï§…Ï?ƒ?½‡ªÿ‘?¬‘æî‘?ð‘?©Æû¾ƒ?«…ù?ƒ?ÿƒ?ÿ‚?î‘øÿ‡?¾‘?ÿ‘¾æ‘ñª‘澇?¾ƒ?ü‘û¸‘¾Ï‡?ñ‘û¾ƒ?ï‘ûæƒ?¾‘­œŠñ­‘?©‘?ÿƒ?ïƒ?ª‡?î‡??‡?­‡?¾ƒ?ýƒ?χ?­‘?øƒ?ªƒ?ù…︃??ƒ?ÿ‘?ÿ‡?©‘?ý‘§?ƒ?¾ƒ?ª‡­¾‘??‡?æ‘«¸ƒ?©‘?Ï‘øÿƒ?­‘«œ‘æð‘û­‘?Ï…ï©…ï?ƒï?‘??‡?ªƒ?ªÆ¬ðƒ?ªÆ¬î…ù?ƒ?ÿƒ?ÿ‘??‘¾Ý‘­œƒ?¾‘?œ‘ïÿ‡?¾‘?ü‘?õƒ?©‘¾?‡?ÿ‡?îƒ?ü‘û¾‡?¾‡?ÿ‘?©‘?ÿ‘æî‘?ð‘?©ƒ?¾‘«?‘?ú†?ý‘?ù‘ñª‘?©‘?÷‘?ÿ‘û­ƒ?ü‘¾?‘?©‡?î…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒñª‡?ÿŠ?ý‘¾Ý‘?÷ƒ?§‘?ªƒ?ü‘?ø‘?ýЏð‡?ï‡?¾‘?ÿƒ?¾‘?ª‘?ÿ‘æî‘?ð‘?©ƒ?¾‡?­‘?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ïƒïùƒ?¸‡?¾…ù?ƒ?ÿƒ?ÿ‘«©ƒ?©‘?øƒ?ü‡?­‘?¾‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æƒÿÿƒÏîƒ?©‘«?‡?æ‡?ÿ‡?î‘?ôƒ?§‡?æ‘ñ¸‡?¸‡?¾‡?ÿƒ?©‘¾ï‘?ýƒ?ï‡?î‡?ÿ‘?©‘?ÿ‡?­‘?ý‘¬ÿ‘ñ½‡?¸‘?æ‘?ÿ‘û­ƒ?ü‘柃ûχ­¾ƒû¾…ù?…ù?†­?„æ?„ñ?†??…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ†??‘«Ÿ‡?©‘ñî„?¾‘ñ¸ƒ?¾‡??†?ª‘?©„¾øƒû©‡??Æ?œ…ù?ƒ?ÿƒ?ÿ‘«?‘?ú†?ý‘?ù‘ñªƒïÿ‘?ô‡?ý‘«¸ƒ?©ƒ÷ýƒ?ø„÷ð„ñî‘?îƒ?î„Ïð‡?©‡?æ‘«?‘æý‡?­‡?ÿ‡­¾ƒ?ð‡?æ‡?ø„?ï‡?î‘?ðƒ?ï„æ?…æ?ƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘û݇?õ‘?ý‘¾ï‘ûî‘??‘?ð„?ÿ‘æÏ‘û¸‘«?‘?ª…æüƒ??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©‡ªÿ‘??ƒæï‡??‘û¾„ñï‘?îƒïÿ‘«?„ûõ‘æ­ƒ?¾‘?ü‡?œ‘¾ý‡¾ï…櫃??ƒ?ÿ†?ÿ‡?î‡?¾‘­?‘ñ¾ƒ?ª„?ð‘æî‘?ð‘?©ƒ?ÿƒ?Ý„?¯‡?¾„?ð‘?ô‡?©‘«?ƒ?õ„øð‘?î‘??‘?ð‡?ÿ‘?¾‡?æ‡?¸‡æû…ï½…ï?ƒ??ƒ?ÿƒ?ÿ†?ÿ‡?îƒ?ý‡?æ‘ñ¸‡?¸‡?¾‘øÿƒ?¾‘?ø‘?ýЏð‡?ïƒ?¾„?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?υ遼??ƒ?ÿƒ?ÿ‘«œ‘æð‘û­ƒ?σ?«‘?õ‡?¸ƒ?ÿƸœ‡??‘«ý‡?õ‘æ­‘?ÿ‘ñ¸‡?¾ƒ?½…ïõƒ??ƒ?ÿƒ?ÿ‡¾½‘?ïƒ?üƒ?«†??‡?û‘?ïƒûð‘??‡?÷„?©‘?©‘?î‘û¸†æõÆù§‘û?‘?¸‘?îƒû¾‘??„?ï‡?û‡?¾ƒ?ù‘«œ‘æð‘û­ƒ¾Ï…ù?ƒ?ÿƒ?ÿ‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?σ?«„??‘ûî‘?ô‡?ýƸ?†?§„?î‡?­Æ?¾†?ï‡?ï‘û¸ƒ­õ‘?χ?û‡?¾…︃??ƒ?ÿ‡?ÿ‡?î‡?¾‘­ü‘ñ¾ƒûª‡­¾ƒ?¾‘?ð‘?©‘?î‘?¾‘«Ÿ‘æð‘û­ƒ?Ï‘?Ï‘?©‘?î‘?¾‘«Ÿ‘æð‘û­…æÏ„Ï?‡?ð‡?ü‘ñ½ƒ?¾‘?χ?ÿ‘?ý‡?¸‡?¾‘øÿƒ?­‘«œ‘æð‘û­‘?Ï‘?ÿƒ?©‘?ý‡?¸‘ûî‘?ÿ‡?õ‘?©‡?ÿ‘ñ­‡?¾ƒ?ý‘?χ?ÿ‡?­‘æ­‡??‘?ý‘Ïÿ‘?©‡?î‘?ý‡?œƒû¾ˆ÷ÿ‡?¨‡?÷ˆ¨¨‘÷ÿ‘?õ‡?ü‡?ÿ‡?­‡?ÿƒ?©‘«Ý‘æý‡?­‡?ÿ‘ñ­‘?¸ƒû¾„øÿ‡?¾‘?ÿ‡?î‘?ð‡?ï‡?ÿ‘ñ­‘?¸‡?¾‡?ÿ‘ûî‹«ï…阮??‡­¾…æï†ÿ?„ñ?…ù?‘«?‘?©…ù?…ù?
Exit code:  3
- Debian 9.9
Mathieu
July 30, 2019 - 5:52 PM
I just noticed that in the original setup there were two lines of ##
old_removed.extend(removed)
    WAPT.write_param(control.package,old_removed)
By removing the ##, the package installs with a message at the end
NoneTraceback (most recent call last):
  File "c:\windows\temp\wapthz_wv2\setup.py", line 96, in install
  File "C:\Program Files (x86)\wapt\lib\json\__init__.py", line 339, in loads
    return _default_decoder.decode(s)
  File "C:\Program Files (x86)\wapt\lib\json\decoder.py", line 364, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
TypeError: expected string or buffer
- Debian 9.9
raselinary
Registration: Sep 18, 2019 - 4:37 p.m.
September 18, 2019 - 4:45 PM
I received the following message and nothing has been uninstalled!
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
None
Previously removed by wapt:
"1527c705-839a-4832-9118-54d4Bd6a0c89", # (10.0.17763.1)",
"7EE7776C.LinkedInforWindows", # (2.0.1.0)",
"AppUp.IntelGraphicsControlPanel", # (3.1.0.0)",
"AppUp.IntelOptaneMemoryandStorageManagement", # (17.0.1011.0)",
"CyberLinkCorp.th.Power2GoforLenovo", #(8.0.8621.0)",
"CyberLinkCorp.th.PowerDVDforLenovo", #(14.1.8627.0)",
"E046963F.LenovoCompanion", #(4.26.43.0)",
"E2A4F912-2574-4A75-9BB0-0D023378592B", # (10.0.17763.1)",
"F46D4000-FD22-4DB4-AC8E-4E1DDDE828FE", # (10.0.17763.1)",
"InputApp", # (1000.17763.1.0)",
"Microsoft.AAD.BrokerPlugin", # (1000.17763.1.0)",
"Microsoft.AccountsControl", # (10.0.17763.1)",
"Microsoft.Advertising.Xaml", # (10.1804.2.0)",
"Microsoft.AsyncTextService", # (10.0.17763.1)",
"Microsoft.BingWeather", # (4.25.12127.0)",
"Microsoft.BioEnrollment", # (10.0.17763.1)",
"Microsoft.CredDialogHost", # (10.0.17763.1)",
"Microsoft.DesktopAppInstaller", # (1.0.22011.0)",
"Microsoft.ECApp", # (10.0.17763.1)",
"Microsoft.GetHelp", # (10.1706.10441.0)",
"Microsoft.Getstarted", # (6.13.11581.0)",
"Microsoft.HEIFImageExtension", # (1.0.11792.0)",
"Microsoft.HEVCVideoExtension", # (1.0.12203.0)",
"Microsoft.LockApp", # (10.0.17763.1)",
"Microsoft.MPEG2VideoExtension", # (1.0.6.0)",
"Microsoft.MSPaint", # (4.1807.12027.0)",
"Microsoft.Messaging", # (3.43.27001.0)",
"Microsoft.Microsoft3DViewer", # (4.1808.15012.0)",
"Microsoft.MicrosoftEdge", # (44.17763.1.0)",
"Microsoft.MicrosoftEdgeDevToolsClient", # (1000.17763.348.0)",
"Microsoft.MicrosoftOfficeHub", # (17.8918.5926.0)",
"Microsoft.MicrosoftSolitaireCollection", #(4.1.5252.0)",
"Microsoft.MicrosoftStickyNotes", # (2.0.13.0)",
"Microsoft.MixedReality.Portal", # (2000.18081.1242.0)",
"Microsoft.NET.Native.Framework.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Framework.1.7", # (1.7.25531.0)",
"Microsoft.NET.Native.Runtime.1.6", # (1.6.24903.0)",
"Microsoft.NET.Native.Runtime.1.7", # (1.7.25531.0)",
"Microsoft.Office.Desktop", # (16040.10730.20103.0)",
"Microsoft.Office.OneNote", # (16001.10228.20003.0)",
"Microsoft.OneConnect", # (5.1807.1991.0)",
"Microsoft.PPIProjection", # (10.0.17763.1)",
"Microsoft.People", # (10.1805.1361.0)",
"Microsoft.Print3D", # (3.0.1521.0)",
"Microsoft.ScreenSketch", # (10.1806.2112.0)",
"Microsoft.Services.Store.Engagement", # (10.0.18101.0)",
"Microsoft.SkypeApp", # (14.26.95.0)",
"Microsoft.StorePurchaseApp", # (11805.1001.8.0)",
"Microsoft.VCLibs.110.00.UWPDesktop", # (11.0.61135.0)",
"Microsoft.VCLibs.140.00", # (14.0.26706.0)",
"Microsoft.VCLibs.140.00.UWPDesktop", # (14.0.26905.0)",
"Microsoft.VP9VideoExtensions", # (1.0.12342.0)",
"Microsoft.Wallet", # (2.2.18179.0)",
"Microsoft.WebMediaExtensions", # (1.0.12341.0)",
"Microsoft.WebpImageExtension", # (1.0.11551.0)",
"Microsoft.Win32WebViewHost", #(10.0.17763.1)",
"Microsoft.Windows.Apprep.ChxApp", # (1000.17763.1.0)",
"Microsoft.Windows.AssignedAccessLockApp", # (1000.17763.1.0)",
"Microsoft.Windows.CapturePicker", # (10.0.17763.1)",
"Microsoft.Windows.CloudExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.ContentDeliveryManager", # (10.0.17763.1)",
"Microsoft.Windows.Cortana", # (1.11.5.17763)",
"Microsoft.Windows.NarratorQuickStart", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkCaptivePortal", # (10.0.17763.1)",
"Microsoft.Windows.OOBENetworkConnectionFlow", # (10.0.17763.1)",
"Microsoft.Windows.ParentalControls", # (1000.17763.1.0)",
"Microsoft.Windows.PeopleExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.Photos", # (2018.18051.21218.0)",
"Microsoft.Windows.PinningConfirmationDialog", # (1000.17763.1.0)",
"Microsoft.Windows.SecHealthUI", # (10.0.17763.1)",
"Microsoft.Windows.SecureAssessmentBrowser", # (10.0.17763.1)",
"Microsoft.Windows.ShellExperienceHost", # (10.0.17763.1)",
"Microsoft.Windows.XGpuEjectDialog", # (10.0.17763.1)",
"Microsoft.WindowsAlarms", # (10.1805.1361.0)",
"Microsoft.WindowsCalculator", # (10.1805.1201.0)",
"Microsoft.WindowsCamera", # (2018.425.120.0)",
"Microsoft.WindowsFeedbackHub", # (1.1805.2331.0)",
"Microsoft.WindowsMaps", # (5.1805.1431.0)",
"Microsoft.WindowsSoundRecorder", # (10.1805.1941.0)",
"Microsoft.WindowsStore", # (11805.1001.49.0)",
"Microsoft.Xbox.TCUI", # (1.11.28003.0)",
"Microsoft.XboxApp", # (41.41.18001.0)",
"Microsoft.XboxGameCallableUI", # (1000.17763.1.0)",
"Microsoft.XboxGameOverlay", # (1.32.17005.0)",
"Microsoft.XboxGamingOverlay", # (2.20.22001.0)",
"Microsoft.XboxIdentityProvider", # (12.44.20001.0)",
"Microsoft.XboxSpeechToTextOverlay", # (1.17.29001.0)",
"Microsoft.YourPhone", # (0.0.12084.0)",
"Microsoft.ZuneMusic", # (10.18052.20211.0)",
"Microsoft.ZuneVideo", # (10.18052.20211.0)",
"RealtekSemiconductorCorp.RealtekAudioControl", # (1.2.148.0)",
"Windows.CBSPreview", # (10.0.17763.1)",
"Windows.PrintDialog", # (6.2.1.0)",
"c5e2524a-ea46-4f67-841f-6a9465d9d515", # (10.0.17763.1)",
"microsoft.windowscommunicationsapps", # (17.9330.21365.0)",
"windows.immersivecontrolpanel", #(10.0.2.1000)",
Mathieu
September 25, 2019 - 11:29
I keep getting an error on the package; I have over 100 workstations that are showing an error
I keep getting the same message:
NoneTrying to remove Microsoft.MicrosoftOfficeHub
NoneTrying to remove Microsoft.MicrosoftSolitaireCollection
NoneTrying to remove Microsoft.OneConnect
NoneTrying to remove Microsoft.People
NoneTrying to remove Microsoft.WindowsAlarms
NoneTrying to remove Microsoft.WindowsMaps
NoneTrying to remove Microsoft.WindowsPhone
NoneTrying to remove Microsoft.WindowsSoundRecorder
NoneTrying to remove microsoft.windowscommunicationsapps
NoneTrying to remove Microsoft.MixedReality.PortalMicrosoft.BingFoodAndDrink
  File "c:\windows\temp\waptdzylcw\setup.py", line 98, in install
Do you have a solution?
- Debian 9.9
Gaetan
Registration: August 8, 2019 - 10:16
September 25, 2019 - 3:08 PM
does the script run manually on one of the machines experiencing the error work?
Mathieu
September 25, 2019 - 4:30 PM
On my VM, the package is no longer showing an error, even though I haven't made any changes.
But on another machine, when I restart the installation, it's still showing an error.
- Debian 9.9
