Request for console enhancements.
smarzloff
Registration: June 26, 2018 - 1:00 PM
July 15, 2019 - 11:56
Hello.
In the console, when selecting columns, would it be possible to add the detailed OS version? (os_version field from the hosts table)
I'm using version 1.7.4 on Debian 9 (for the server) and Windows 2008 for the console (yes, that one will need upgrading! ;) ).
Thanks in advance. :)
PS: A huge thank you again for this fantastic tool, WAPT! :)
July 19, 2019 - 7:00 PM
Hello smarzloff,
smarzloff wrote: July 15, 2019 - 11:56 AM In the console, when selecting columns, would it be possible to add the detailed OS version? (os_version field from the hosts table)
You can drag and drop a value from the "hardware inventory" tab of a workstation onto the main grid. Then click refresh, and it should populate the column with the correct values. The os_version field is available under host_info / host_capabilities / os_version
Denis Cardon
