WAPT-Exit
Mathieu
Registration: August 18, 2016 - 10:24
July 30, 2019 - 4:36 PM
- Installed WAPT version 1.7.4.6143 Enterprise
- Debian Stretch server OS
- Operating system of the administration/package creation machine (Windows 10)
I just realized there's been a problem for the last 1 or 2 weeks: wapt-exit isn't working on our machines.
During shutdown or reboot, the WAPT-exit window appears very quickly and closes immediately, even though there are packages waiting to be installed.
I have not made any modifications that could prevent it from working properly.
I tried forcing an installation and restarting the machine; the wapt-exit command executed correctly
Here is the wapt-get.ini file for the wapt-exit part:
max_gpo_script_wait= 180
pre_shutdown_timeout= 180
hiberboot_enabled= 0
notify_user = 0
allow_cancel_upgrade = 0
I don't see anything in the logs.
Speaking of logs, I have a colleague who can't connect to the console even though the connection to AD works; he's the only one who won't work. I can't find any logs that can point me towards the problem.
PS: I don't know if I should use the forum or open a support ticket.
Thank you
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
July 30, 2019 - 10:36 PM
Hi Mathieu,
the problem is related to `allow_cancel_upgrade` (a bug recently discovered)
. I plan to release a fix soon.
For the AD connection, you can contact us directly, ;)
Simon.
Mathieu
August 2, 2019 - 09:52
Thank you
, do you have a deadline or should we set the value to 1 while waiting for the correction?
- Debian 9.9
August 2, 2019 - 11:52
I released a version last night that fixes the problem (I just haven't made an announcement yet)
Mathieu
August 2, 2019 - 12:29
Thanks,
I'll do the update this afternoon.
- Debian 9.9
Mathieu
August 2, 2019 - 3:45 PM
Following the update and application of the new agent, WAPT-Exit is working normally.
All that remains is to manually install it on the entire network.
- Debian 9.9
