[RESOLVED] organizational unit package error
Gaetan
Registration: August 8, 2019 - 10:16
August 14, 2019 - 4:17 PM
Hello everyone,
the following package: viewtopic.php?f=9&t=1925
works very well, one station at a time.
However, as soon as it is placed in an OR, it gives this error:
installing tls-agent-kav-10-installerTraceback (most recent call last):
File "C:\Program Files (x86)\wapt\common.py", line 3846, in install_wapt
File "c:\windows\temp\waptmsjbkd\setup.py", line 18, in install
File "C:\Program Files (x86)\wapt\common.py", line 3802, in new_func
return func(*args,**kwargs)
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 4157, in install_msi_if_needed
run(r'msiexec /norestart /q /i "%s" %s' % (msi,props),accept_returncodes=accept_returncodes,timeout=timeout,pidlist=pidlist)
File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1061, in run
CalledProcessErrorOutput: Command 'msiexec /norestart /q /i "Kaspersky Network Agent.msi" PRIVACYPOLICY=1 LAUNCHPROGRAM=1 EULA=1 SERVERADDRESS=10.31.8.47 DONT_USE_ANSWER_FILE=1' returned non-zero exit status 1603.
Output:
Output:
I understand the output, because WAPT does not retrieve an expected return value.
My question is: Why this error on the ORs and not the positions?
THANKS
August 14, 2019 - 6:57 PM
There's no connection to OU packages.
However, I doubt error 1603 is expected. ^^
https://support.microsoft.com/fr-fr/hel ... stallation
Gaetan
August 19, 2019 - 09:56
indeed, it's not expected; it only appears if the application is already present.
But only on a deployment via the OU, not on a peer-to-peer basis.
So I don't understand the difference between the two types of installations.
Could you explain how I can correct my package, please?
Gaetan
August 21, 2019 - 10:16
I managed to work around the problem by modifying the code (updated in the other post).
But I still don't understand why the error was present in the OU and not in the peer-to-peer interaction.
August 21, 2019 - 10:28
I admit to having behaved strangely with the Zabbix package...
