Multi-user installation possible?
PierreM
Registration: May 1, 2019 - 03:39
August 22, 2019 - 10:58
Hello everyone,
sorry if this question has already been asked, but I couldn't find the answer.
We have 400 computers, and I want to install a package on all of them at the same time. Is this possible?
I tried selecting all the machines and then allowing packages, but it doesn't work.
Is this the correct action? If it works, I get an error. If not, how do I do it?
Thanks in advance, and have a good weekend!
Gaetan
Registration: August 8, 2019 - 10:16
August 23, 2019 - 11:03
are the computers grouped in an OU?
If so, you just need to edit the OU package.
vcardon
August 23, 2019 - 3:24 PM
Note that associating packages with an Active Directory Organizational Unit is a feature of the Enterprise edition.
Perhaps PierreM is using the Community edition.
In the Community edition, you can create a group (e.g., "core") that groups the machines and assign the software you want deployed to that group.
This method is very convenient. However, if you want a machine to exclude a particular application from the group, you will need to remove the machine from the group and manually apply its configuration, or assign it to a different group.
Vincent
PierreM
August 27, 2019 - 03:57
Hello and thank you for your reply. Yes, I am indeed using the community version.
I will therefore group the machines.
Thank you and have a good week everyone!
