[SOLVED] MD5 error when importing from the Internet
avondra
Registration: Nov 9, 2016 - 12:02
August 30, 2019 - 10:51
WAPT 1.6.2.7
CentOS 7.6 server OS
Windows 10 admin machine operating system
I am having trouble updating packages imported from the internet to the tranquil.it repo; with each import I get a message about a corrupted package due to an MD5 sum error. I have purged the local cache without success.
Do you have any ideas on how to solve this problem?
Thank you for your help
Gaetan
Registration: August 8, 2019 - 10:16
September 2, 2019 - 11:49
have you tried restarting the server?
September 2, 2019 - 1:05 PM
an update to version 1.7 of wapt should resolve the issue!
avondra
September 2, 2019 - 4:35 PM
rebooting doesn't change anything. I don't understand why this happened suddenly; everything was fine a week ago, and I haven't made any changes to this server.
I wanted to upgrade to version 1.7, but now it's more urgent, if there's no other solution, because I can no longer perform updates.
September 2, 2019 - 4:46 PM
We simply updated the wapt.tranquil.it repository to version 1.7, and the filename format changed, which is causing your problem since version 1.6 had a bug.
In the meantime, you can manually download the wapt package here: https://wapt.tranquil.it/wapt/?C=M;O=D and import it as a file into the console.
Since version 1.7 was released in February 2019, we thought our users would have had time to update...
avondra
September 2, 2019 - 4:58 PM
Thank you for the answer, I understand the reason now.
