We can patch wapt-get.py to allow this information to be passed via the command line...
Add 2 options to the parser.
parser.add_option("--wapt-server-user", dest="wapt_server_user", default=None, help="User to upload packages to waptserver. (default: %default)")
parser.add_option("--wapt-server-passwd", dest="wapt_server_passwd", default=None, help="Password to upload packages to waptserver. (default: %default)")
Add the values to the call to build_upload:
res = mywapt.upload_package(cmd_dict,wapt_server_user = options.wapt_server_user,wapt_server_passwd=options.wapt_server_passwd)
print('Status : %s, %s' % (
@@ -134,6 +134,8 @@ parser.add_option("-U","--user", dest="user", default=None, help="Interactive us
parser.add_option("-g","--usergroups", dest="usergroups", default='[]', help="Groups of the final user as a JSon array for checking install permission (default: %default)")
parser.add_option("-t","--maxttl", type='int', dest="max_ttl", default=60, help="Max run time in minutes of wapt-get process before being killed by subsequent wapt-get (default: %default minutes)")
parser.add_option("-L","--language", dest="language", default=setuphelpers.get_language(), help="Override language for install (example : fr) (default: %default)")
+parser.add_option("--wapt-server-user", dest="wapt_server_user", default=None, help="User to upload packages to waptserver. (default: %default)")
+parser.add_option("--wapt-server-passwd", dest="wapt_server_passwd", default=None, help="Password to upload packages to waptserver. (default: %default)")
(options,args) = parser.parse_args()
@@ -742,7 +744,7 @@ def main():
'waptfile': files_list,
'waptdir':package_group[0],
- res = mywapt.upload_package(cmd_dict)
+ res = mywapt.upload_package(cmd_dict,wapt_server_user = options.wapt_server_user,wapt_server_passwd=options.wapt_server_passwd)
res['status'], res['message']))
