WAPTUpgrade Update
joris.remandet
Registration: January 16, 2018 - 6:29 PM
September 4, 2019 - 4:05 PM
Hello everyone,
Back on the forum after encountering an error while retrieving packages from the repository, I started upgrading from version 1.6 to version 1.7. Everything went smoothly, except that the waptupgrade package isn't updating:
Here's the message I get: "
Your current wapt (1.6.2.7) is the same as or more recent than the upgrade package (1.6.2.7-8). Skipping..."
I'm running WAPT 1.7 on Debian Stretch,
Windows 10 1803 administration console.
How can I fix this, as I'm not sure where to begin? ;)
Thanks in advance,
Joris
Yoann
Registration: July 24, 2019 - 09:39
September 5, 2019 - 11:25
Once the WAPT server is updated, it is necessary to update the WAPT administration console (waptsetup-tis.exe) to generate the new version of the WAPT agent. The WAPT console version is displayed during authentication and in the status bar.
Please be careful to clear your web browser cache before downloading WAPTSetup from the web repository.
Regards.
WAPT Community 1.8
joris.remandet
September 5, 2019 - 12:35
thank you for your reply. That's exactly what I did; I always download from a different browser when I update.
I've even noticed that since the server update, I'm having trouble even with waptdeploy (I think my server has a small problem).
I'm going to try completely uninstalling the WAPT console, reinstalling it cleanly, and creating a new package.
Edit: Well, I reinstalled the command and cleared the browser cache, but unfortunately, I still have the same problem. Regarding my deployment via GPO, I did update WAPTdeploy and the hash, but when I reboot my machines, the waptdeploy window only appears on two machines at a time, which is why I think my server has a small problem...
