Hi!
This is probably a really silly question, but:
How do I copy multiple files at once to a directory?
My package contains a directory with several files, and I'd like to copy its entire contents to another directory during installation.
The `filecopyto` function, if I understand correctly, only allows me to copy one file at a time...
Thanks,
Chris.
Multiple file copies
- kguerineau
- Registration: March 6, 2018 - 4:28 PM
To copy multiple files into a directory, you can use the copytree2 function.
https://dev.tranquil.it/sphinxdocs/sour ... .copytree2
Regards
Regards
Christophe0110
- Registration: June 11, 2019 - 12:04
Hi kguerineau,
thanks for your reply.
However, if I want to copy all .exe files (*.exe), for example, can I also do that with this function?
Cheers
Cheers
- WAPT Expert
import glob
for f in glob.glob('*.exe')
filecopyto(f,'c:\\toto\\')
Christophe0110
Thanks for your reply.
I finally did something similar using the os.listdir function.
