[SOLVED] Selecting multiple machines in the WAPT console
Qi-support
Registration: August 29, 2016 - 4:15 PM
September 16, 2019 - 4:31 PM
We are using WAPT with console version 1.6.2.7. The OS is Windows Server 2008 R2.
Deployment works perfectly when a single machine is selected.
Deployment does not work if multiple machines are selected because the "Edit Machine" function is grayed out.
Do you have a solution?
Best regards,
ALN
September 16, 2019 - 6:14 PM
you must use the "add a dependency" button,
then "check for updates" or directly "Start the installations".
Qi-support
September 24, 2019 - 10:37
I will be on site this week and will keep you updated on the situation.
Thank you for your feedback.
ALN.
