[SOLVED] Cleanup - DEBIAN - wapt 1.6.2.7
traumatism
Registration: February 20, 2019 - 1:37 PM
September 27, 2019 - 3:39 PM
Hello everyone,
I'd like to know how to clean up the WAPT server. I have a 20GB hard drive, and when I update my packages, it takes up more space but doesn't remove the old packages.
Thank you.
Best regards.
October 4, 2019 - 7:51 PM
Good evening, tromatism.
tromatism wrote: September 27, 2019 - 3:39 PM Hello everyone,
I would like to know how to clean up the WAPT server. I have a 20GB hard drive, and when I update my packages, it takes up more space but doesn't remove the old packages.
Thank you.
Best regards.
WAPT does not automatically decide to remove your packages from the repository (you might want to keep them...). You must go to the "private repository" tab and then remove them yourself.
PS: There are lots of improvements in version 1.7, I advise you to upgrade.
