HTTPError:405 Client Error: METHOD NOT ALLOWED
mbaudouin
Registration: Sep 30, 2019 - 11:56
September 30, 2019 - 12:12
after installing WaptServer on a Debian system, I get an error message when connecting to the WAPT server via the console installed on my Windows 7 PC.
When I launch the console, it asks me to generate the waptagent.exe package, but I encounter a problem uploading it.
Error creating waptagent.exe: Unable to create WAPT update package
HTTPError: 405 Client Error: METHOD NOT ALLOAD for url:
https://
This looks like an upload permissions issue, but I don't know where to look (my tests modifying the permissions in /var/www/wapt didn't help).
Similarly, importing an existing package gives me the same type of error.
Thank
you for your help.
- Installed WAPT version (1.7)
- Server OS (Linux Debian 10.1)
- Administration/package creation machine OS (Windows 7 - console 1.7.4.6165)
September 30, 2019 - 4:43 PM
mbaudouin wrote: ↑Sep 30, 2019 - 12:12
https://
hTTTime?
mbaudouin
September 30, 2019 - 4:54 PM
sfonteneau wrote: ↑September 30, 2019 - 4:43 PM
https://
hTTTime?
Yes, it's HTTPS. Do you see anything wrong? (There are only two Ts; I copied it incorrectly in the first message.)
2019-09-30 17_03_26-Console WAPT.jpg (26.88 KB) Viewed 6052 times
September 30, 2019 - 5:02 PM
If it's a copying error... then it's not that.
I don't know.
October 4, 2019 - 7:49 PM
Hello mbaudouin,
mbaudouin wrote: ↑September 30, 2019 - 4:54 PM
https://
hTTTime?
Isn't there another web server running on the wapt server?
