I installed a test machine with Windows 10 version 1903. The console correctly displays the machine, and I launch my pending packages. When I run a check, the console correctly displays all my packages that are waiting to be downloaded.
However, when I shut down or reboot, WAPTEXIT does not launch. I tried rebooting several times, but without success.
I performed a test by running waptexit.exe, and the installations then launched correctly.
Waptexit display bug under Windows 10 1903
- WAPT Expert
Does waptexit appear correctly in the shutdown scripts in the local GPO? (gpedit.msc)
- WAPT Expert
And also in gpresult /h wapt.html?
- WAPT Expert
and a gpupdate /force command?
You should have this:
- Attachments
- Capture.PNG (8.34 KB) Viewed 15294 times
I tried it, and it tells me there's an application waiting, but it's a different application that isn't working. It appears in the event logs, but not Wapt; it's as if Wapt hasn't registered itself in the tasks
- WAPT 2.2.3.12463 Enterprise
- Debian 9.9
- Windows 10 21H2 & Windows 11 22h2
- Debian 9.9
- WAPT Expert
With Windows 10, I already encountered a case last week where a local GPO wouldn't apply because a domain GPO wasn't working...
I corrected the GPOs that were in error (damn SMB1 not enabled on W10) following that and the forced installation of the wapt-conf-policy
waptupgrade package to recreate the WAPTEXIT task launches with the display bug
- Debian 9.9
- Debian 9.9
- WAPT Expert
