Hello everyone, I'm working on a new WAPT installation and for this one I'd like to avoid using a replication server. So I've chosen to create WAPT packages for my largest software programs. Something fairly simple like: `
cmd = '\\server_north\software_folder\large_software\setup.exe'`.
Of course, just like with my usual setup, I get that wonderful error message:
"The specified path could not be found."
So I discovered that: The WAPT service runs under a local system account (NT_Authority\System), and this account is complicated for network drives with my Samba domain controller.
So I tried WAPT's session setup function and, miraculously, it works.
Except, unfortunately, it only works if the user has access rights to that network location, and if it's open and they enter their password at least once.
So I have a starting point: with the command
cmd = 'net use * \\serveur_nord\dossierlogiciel\groslogiciel\ /USER:login mdp'
locally there is no problem but via wapt it gets stuck I must be missing a ' ' or a " "
Finally I am open to any suggestion that would allow me to do without these replication servers.
[SOLVED] Network drive and installation
- WAPT Expert
Putting a password in plain text in a WAPT packet isn't ideal.
Do you absolutely want to do it via SMB?
I'd recommend setting up a small web server instead. Nginx, Apache, or something similar... and then use wget in your packet.
import win32wnet
wnet_connect(host, username, password)
#dès la connexion établie, l'accès au dossier est possible.
def wnet_connect(host, username, password):
unc = ''.join(['\\\\', host])
try:
win32wnet.WNetAddConnection2(0, None, unc, None, username, password)
except Exception, err:
if isinstance(err, win32wnet.error):
# Disconnect previous connections if detected, and reconnect.
if err[0] == 1219:
win32wnet.WNetCancelConnection2(unc, 0, 0)
return wnet_connect(host, username, password)
raise errAn example of how to select the nearest server based on the gateway:
def getdownloadserver():
#### Get gateway and set depending server
location = str(get_default_gateways()).split('.')[2] ## third octet of gateway ip address
if location == 0 :
return "10.0.0.X"
elif location == 1 :
return "10.0.1.X"
elif location == 2 :
return "10.0.2.X"
else :
return "10.0.0.X"- sfonteneau
- WAPT Expert
Remember to make a copy rather than launching the installer directly from the network drive. This avoids a number of problems
